Question about Denon AVR-2802
Power comes on for only about 4.5 seconds, then shuts off.
The standby light stays on, but the main power will not stay on.
  • 2 more comments
  • timmboy Feb 05, 2008
    The standby botton is blinking but no power in the maain unit
  • markcrompton Jun 21, 2008
    I see the same problem. Went away on vacation and unplugged everything. When the receiver was plugged back in it powers up, displays 'Digital AV Surround Receiver' then powers off leaving the ON/Standby light flashing.
    Any updates ideas?
  • sal66219 Jul 21, 2008
    I am having the exact problem, The standby light continually flashes, powers off after two seconds & remains flashing. Any thoughts on how to fix it? All the connection points appear to be fastened tightly. Thanks!
  • fdami98 Sep 12, 2008
    Once I turn the power on , it comes on for about 5 seconds and shuts off leaving the standby light on and flashing. I'd unplugged the unit for days and still experiencing the same problem
  • 682 Answers
1-speakers terminals are short circuit----turn it off and correct speakers terminals.
2-blocking of ventilation holes of the set -------turn it off and let it cool down and make a good ventilation around ventilation holes.
3-the unit is operated at continuous high power condition------turn it off and let it to cool down and then turn it on.
Posted on Aug 04, 2008
How to determine if power board on emerson tv model lc320em1 is shot
The power supply regulator board to your TV is now working fine, and has no problems at all, as, there is standby light. Check all the other voltages comes out from the power board, to main board. If all of it found OK, the fault should be at its main board.
About blinking of standby/power light;
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | Emerson Lc320em1 TV
Sony KDL46V2000 TV. Screen comes on and goes off in continuous cycle
you have a leaking cap on your power supply /open up and check on just replace those caps that looks swollen
Nov 16, 2017 | Sony KDL-46V2000 46 in. LCD Television
POWER LIGHT GOES FROM RED TO GREEN WHEN POWER BUTTON IS PRESSED WITH INSTANT ON AND THEN OFF, WHY THE UNIT DON'T STAY ON?
something clearly is wrong which is why it shuts off:
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
Apr 02, 2012 | Soyo DYLT032D 32 in. LCD Television
My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Aug 29, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
No power up
The YSUS Board Was Bad
Dec 31, 2008 | Maxent MX-42XM11 Television
Comuter will not stay in standby mode.
So why do you need the computer in stand-by mode anyway? My computers are either on or off. Off saves power and hardware.
Dec 25, 2008 | Computers & Internet
Tv won't stay on
MY SAMSUNG 27# MODEL TXT27820 ONLY NINE MONTHS OLD SHUTS OFF BY ITSELF AND WILL NOT START AGAIN
May 10, 2008 | Samsung TXJ2754 27" TV
Denon AVR-2802 Logo
281 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
