Question about Samsung SGH-D900 Cellular Phone
Broken lcd screen
How do you remove the covers to replace the screen?
    Brigadier General:
  • 7,752 Answers
You can source that on or take the phone to a professional repair store and have that done.
Posted on Jun 29, 2008
How to replace a video cable
In a Gateway M-7351u Notebook PC?
Motherboard side of video cable, should be under the Switch Cover, (LED indicators, Power On button, speakers, etc), or under the Keyboard close to the Switch Cover.
Don't forget to remove ALL power. Remove the AC adapter (Charger), and Battery. (Use CARE. Wires going to Switch Cover. Do not cut them by accident, or pull on them when removing Switch Cover )
Oct 24, 2012 | Gateway M-7351u Notebook
My kodak easyshare c603 has a deffect in lcd where can i get the lcd to be replace ?
Repair cost is too much. Do it yourself.
Buy a used camera (one sold for parts) from You may be able to get it very cheap. Then replace the LCD from the one you bought to your old one. A new LCD screen from shop will be expensive. I wont advice you to get a new one.
The only tool you need a small screwdriver set (buy it for $1 from Dollar store). Remove the camera cover by removing 5-6 screws. Once the cover is removed, LCD is accessible. The LCD cable is connected through a connector to the main board. There is a pressure plate in the connector, simply lift it and pull the cable out and remove your LCD. That simple. Replace in the reverse order.
Two sites to give you step by step directions:
Jan 13, 2011 | Kodak EasyShare C603 Digital Camera
There is a good site, which explains how to replace the LCD screen.
It is not difficult. Open the cover by removing 5-6 screws. LCD screen is immediately accessible. You can do it yourself.
Jan 04, 2011 | Cameras
The screen seems broken, when i connect it to the computer, it doesn't react but the little power light flashes.
remove power; remove the back cover and, look for a "domed not flat, top on a can capacitor replace the capacitor that has failed
Jul 17, 2010 | Acer AL1716 17" LCD Monitor
How to remove broken screen and replace with a new one on nokia 6350-1b
at first remove all screw from your ph, then you will see a clip beside of lcd. you unlock that one and put there new one
Jul 15, 2010 | Nokia Cell Phones
Is it possible to fix the view screen if just the glass (not the ldc) is broken? Fuji FinePix Z5fd
There is a plastic cover over the LCD. Is only the cover broken? The plastic cover is easily replaceable.
But there is also a sheet of glas over the LCD. This is a part of the LCD assy and cannot be replaced without replacing the entire LCD.
Feb 08, 2010 | Fuji FinePix Z5fd Digital Camera
How to change out a broken lcd screen on an aspire
This is its contents without the pictures:
OK, let’s get inside the display assembly.
First of all, turn off the laptop, unplug AC adapter and remove the battery.
The screen bezel* has four screws hidden under for seals. Two rubber seals on the top of the bezel and two plastic seals on the bottom.
You can remove all four screw seals with a sharp object as it shown on the picture below. Glue removed seals somewhere on the bezel so they don’t get lost.
Remove four screws found under seals.
Start remove the screen bezel with your fingers. Proceed slowly while removing the bezel.
Carefully separate the display cover from the screen and access the LCD cable connector
You’ll have to unplug the LCD cable from the screen.
First, unglue the clear sticky tape securing the connection.
Second, unplug the LCD cable from the connector on the screen.
Here’s how you can remove the LCD screen.
Simply remove four screws securing the LCD screen to the display hinge. Remove four more screws from the other side of the screen.
Now you can remove and replace the LCD screen with a new LCD screen.
Put all the screws back in there places
Dec 31, 2009 | Acer Aspire One PC Notebook
I have a brocken panel tv lcd42hd-09 were i kent find a new panel
In most (if not all cases) it is cheaper to buy a new tv as to replacing the broken LCD. The odds of finding an exact match tv with other problems other than a broken screen is not very likely. To purchase a replacement out right is incredibly expensive. If it's not under warrant (or even if it is) a broken screen is not a manufacturers defect and they won't cover it. Just an example. I have a 46" Sony Bravia KDL-46V2500 with a screen damaged by a WII striking the screen. Still under warranty but not covered. Replacement screen is between $4,000.00 to $5,200.00 plus the labor to have theold one removed and a new one installed. NOTwoth the price to replace as two much newerand larger TV's can be bought for that kind of noney. So as far as a broken screen goes even the highend models are throw away's.
Nov 12, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Broken screen on Blackberry Curve needs to be
you can use warranty or send it to the company and they will charge you if you hadnt taooken the warranty
Sep 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
Digital camera screen broken
A cracked screen will cost you, but maybe not as much as you think. Instead of replacing the whole , you can spend about $300 and replace the screen yourself. All you need is a small screwdriver.
1)Turn off the power to your screen and unplug all cables connected to it.
2)Remove the battery, if one is installed.
3)Locate the covered screws around the cracked screen. Remove the rubber/plastic covers, then unscrew the screws.
4)Gently remove the plastic frame around the cracked screen and set it aside.
5)Disconnect any power cords or cables going into the LCD screen.
6)Remove the cracked screen and slide the new screen into place. Replace any tape or plastic fasteners that hold it in place.
7)Reconnect all internal cords to the screen.
8)Screw in the frame and replace all the screw covers.
9)Reconnect the power supply and all external cables to the LCD screen and switch it on.
Aug 31, 2009 | Sony Cyber-Shot DSC-P150 Digital Camera
Samsung SGH-D900 Cellular Phone Logo
67 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
