Ford Code-Alarm Code Alarm  Transponder
Problem for Ford Code-Alarm Code Alarm Transponder
Ford transit 1998 turbo diesel red light
By burrasilvest on Sep 14, 2009
No power,
red engine light on dashboard
temperature never hot
Engine sounds OK
turn off ignition, pull keys out, dashboard dead, engine keeps running
HEEEELLLPPP!!!!
Best Solution
posted on Sep 14, 2009
Very Helpful)
silver top
Rank: Guru  Ford Expert
Rating: 88%, 247 votes
this sound like you fuel injector pump stop solenoid is faulty it has an elec wire attached to it that with ign turned on it opens (clicks ) then clicks off/closes the fuel supply to the pump so engine stops ok? however the seal on the valve may have parted from the operating piston valve on solenoid and although it is free to allow fuel enough for start and running will also restrict fuel flow for more revs resulting in power loss as you mention ? also when ign is turned off the valve will operate but seal being not attached to piston ? fuel can still flow/seep thro to f i p and allow engine to continue to run ? hope you understand ?? this solenoid valve is a screw in type normally on top of f i p with a single wire to energize it looks like a larger type of temp sender unit ?
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" Thank you Silver top, I will change solenoid. thought was $$pump$$ it$elf and I decided to lay down and die.locking cams, flywheels, timing, $$$... " - burrasilvest
Popular Solutions for Ford Code-Alarm Code Alarm
Questions and Unsolved Problems for Ford Code-Alarm Code Alarm
Do you recommend Ford Code-Alarm Code Alarm Transponder?
Answer
Answer
my alarm is set and im inside the house, im unsure of my code? if i type it in and its wrong, will... (More)
Answer
have a 2005 Ford Mustang 6 cyl coupe. Have a Code Alarm keyfob that locks/unlocks doors, etc. Was... (More)
Answer
we have 3 dual tech motion detectors. They all have power to them but none of them work.They seem... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ford Code-Alarm Code Alarm ...:
Top Car Security System Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Car Security System Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
