Master reset when switched on goes to black screen then turns blue screen and turns off
    Genius:
  • 1,226 Answers
Just suggestion. Kindly verify your memory that is one source of blue screen. the other one is if you have installed new hardware. u can diagnose the system by uninstalling the new hardware and reboot. if you have the same problems after such method accomplished. most likely the power supply should be examine first, the memory i stated above. and also the motherboard. based on the problem u stated, a processor is most likely good. hope u enlighten.
Posted on Dec 12, 2007
Turns on but black screen
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Oct 04, 2013 | MSI Wind U100-030US Laptop
Ok so my netbook goes to a blue screen where it says " press f2 to run setup, press TAB to display BIOS POST message" and stays there. if i push f2 then it goes to a black screen where at the...
Probably the hard drive is dead. Did you drop it recently? Anyway, it could be just the connector, if your good with hardware you could open it and check. I would suggest you to use the warranty though.
Mar 03, 2011 | ASUS Eee PC 1000HE Netbook
I have a 98 Windstar none of the power windows work. Door locks work. I checked fuses I have cleaned the switch contacts if i put power to motor it works.
OK, so looking at this logically, it would make sense that the window motors are not getting power....If the fuses are good, then where is the power failure?
Firs of all, the main power for the window motors comes from a 30 Amp circuit breaker in the Engine Compartment Fuse Box....not a fuse. This supplies power to the Delayed Accessory Relay located in the Instrument Panel Fuse Block, which in turn provides the power to the driver's door master window switch.
If I were working on this vehicle, I would check for battery voltage at connector Pin #6 (Blue/Black wire) at the driver's door master switch. If there is no power there, then I would check for power at the relay terminals. With the key in the RUN position there should be 2 of the Delayed Accessory Relay pins with battery voltage. If one of these is missing, then you will have to look toward the circuit breaker and the battery. (There is also the Generic Electronic Module and the Battery-Saver Relay involved in this.)
If there is power on two pins of the Delayed Accessory Relay , then the most likely cause of your problem would be that the Blue/Black wire is broken inside the umbilical where it goes between the body and the door.
If there is power at the Blue/Black wire at the driver's door master switch, then your problem is probably ground-related. The solid Black wire in pin #7 at the driver's door switch goes through the umbilical to ground # G202, which is located at the left side kick panel area under the dash. This wire could likely be broken inside the umbilical also.
Please also review this article: Where's The Fuse?
Your votes and ratings are appreciated.
Feb 27, 2011 | 1998 Ford Windstar
Camera suddenly will not record
This looks like a relay or micro switch has gone, camera needs looking at.
Jun 20, 2010 | Panasonic NV-DS65 Mini DV Digital...
My Action Replay DSi starts up with white screen.
i saw a vid that shows you how you MIGHT be able to fix this heres the link: http://www.youtube.com/watch?v=l7jshKuBcaI
Feb 20, 2010 | Video Game Consoles & Games
My nokia 3110c is not switching on
Check if battery on the phone depletes fast. If there's nothing wrong with the battery try poercycling the phone (turning phone off and removing battery from the back and insert battery after 1-2 mins). If the problem persist try master resetting the phone. Remember that by doing the master reset it will delete some of your saved info on the phone.
Sep 05, 2009 | Nokia 3110 Cellular Phone
ZEN V PLUS - BLANK SCREEN - BLUE LIGHTS ON WONT SWITCH OFF
plug into computer
press reset butten
make use of the warenty that came with it
May 18, 2008 | Creative Labs ZEN V Plus MP3 Player
Boots in IM mode
its obviously a software issue.....you will probly need to do a master reset....to do this, go to start, accessories, clear storage
Nov 09, 2007 | T-Mobile Dash Smartphone
Computers & Internet Logo
189 people viewed this question
Alun Cox
David Payne
David Payne
