Question about Foxconn 661M03-G-6EL Motherboard
HELP ME I DON'T KNOW WHERE I PUT THE 3 SMALL CABLES OF HD LED,POWER LED,AND RESET,TO START THE COMPUTER,WHERE I FIND THE MANUAL
  • 1 more comment
  • hoh1 Dec 14, 2007
    Will not complete POST if a HDD is connected to either integrated IDE connection. completes ok and runs memory test if only floppy disk in connected.
  • Anonymous Mar 09, 2008
    http://www.foxconnchannel.com/en-us/prod...
  • Philllll Apr 09, 2008
    i really need a picture of where i can plug the damn powering switches for the stupid motherboard
    Champion:
  • 209 Answers
You can identify this in your motherboard on where you can connect these, there are identifications which are written in your motherboard like power on, reset, hdd led. just look closely or maybe you need to use a magnifier because they're too small
Posted on Dec 11, 2007
Please help!
What are possible reasons that only power LED is on?
1) LAN & Internet cables are not connected to powered devices. Check cables and devices connected to D-Link ports.
2) Power supply failure. Try to replace AC adapter.
3) SW error. Try to reset deivce to factory default by reset button. It is placed on rear panel in small hole.
Manual is available here:
http://www.dlink.com/-/media/Consumer_Products/DIR/DIR%20600/Manual/DIR_600_B_2_Manual_EN_UK.pdf
Nov 19, 2013 | D-Link DIR-600 Router
I'm working on an Emachines T3624 I took out the front panel connectors and I can't remember where the power switch connects to the motherboard. I know the general area but I don't know the exact spot....
The manual can be downloaded here, just click on "drivers and downloads" and follow it out.
http://support.gateway.com/us/en/emac/default.aspx
I was hoping to refer you to the manual to provide a diagram, but the manual does not show the front panel I/O connections, so I'll give you general instructions.
The front panel header is a set of two rows of pins. You may need a magnifying glass and flashlight to see the small print on the motherboard that identifies the pins. Look at your front panel cables and look for the same abbreviations on the circuit board. You should see "pw sw" (power switch), "rst" (reset), HDD (hard drive activity indicator LED), and "pw" (indicator LED that shows that the computer is powered up. There should also be speaker.
Just match the cables to the pins on the motherboard. Polarity ( + or - ) is only important for the LED's ( pw and HDD ) Don't worry, if you connect them wrong, they just won't work, just swap wires.
Apr 29, 2011 | E-Machines T3624 PC Desktop
Have soyo p41875p dragon 2 motherboard v1.0 and need to know front panel settings to hook up the power led, hd led, sw, reset and so forth. think it's in the j25 cluster but don't have a manual for to get...
try like this..(cause they went out of mo bo business and there are no downloads available..)
keep in mind the pins numbered like this ..
2 4 6 8 10
1 3 5 7 9
where 1 is the edge left of the board
and the wiring wil be ..
1 HD+
3 HD-
2 msg led +(powe/slp)
4 msg led - ...........
5 restart -
7 restart +
6 power +
8 power -
Im not totally sure about the restart if they are really inverted ..but from what I remember there was the issue ..
Aug 22, 2010 | Soyo Computers & Internet
Cables on motherboard
These are the cables from the front panel of your computer.
power/reset buttons, led light from power on button/hdd activity etc.
The manual for your motherboard will tell you where they go.
They fit on the two rows of pins, usually at the bottom left corner of the motherboard,
I agree with you, they are very fiddly and the manual is not usually very clear how to attach them
Jul 11, 2010 | Computers & Internet
IVE TOOK MY COMPUTER APART AND PUT IT BACK TO GETHER BUT I DONT NO WHERE TO PUT MY HD LED ,POWER LED, POWER SW, RESET SW SOME 1 HELP ME BECAUSE I NEED MY PC WORKIN LOL I PUT DEM IN A PLACE BUT WHEN I PUT...
on board it sould say hd power reset on the front panel on board use manual that it came with or you go to libary go to web site of board type s740mp will tell you the maker of board go there type in board number go to manual then print it out ok jim
Feb 19, 2010 | AMD S740MP (S740MP-1800) Motherboard
Need front panel pin colour code
The two green cables are for power LED, one + and one -. Then there are two yellow cables for the HD LED, with one + and one -. The red ones are for ON/OFF (power button), and the blue are for reset. So yeah, you are technically right if I understood what you said xD
May 21, 2009 | EliteGroup EZ-BUDDIE (ezbuddiep4) Barebone
49p1605 manual
Start up your computer, Hit F1 go to Bios and see which is the model number of your IBM motherboard (usually is a number like this: 8313-BU7 (example))
Then go to Lenovo.com >> Support Drivers
Select >> Desktops >> Netvista >> Model Number (put yours) >> OS
And get the drivers and all the info about your machine.
Please dont forget to rate my help! :-) Have a great day!
May 01, 2008 | IBM (49P1605) Motherboard
Asus a8v fail
does the power supply fan run when switched on.
does the hard drive spin up .
Have you reseated the video card.
Jan 26, 2008 | ASUS A8V Deluxe Motherboard
Install
well those connectors are usually placed in the lower right part of the motherboard. And also there is small writing near those connectors that tell u what to put where ...
U can't do any damage if u put them in the wrong position.... so no worries ....
usually PW - power switch
ReS - reset
SPEAK - speaker
HD - harddisk status led
MSG - message led - that shows u the power is on
But the best thing to do, is to check u;re motherboard user manual !!!!
Jan 19, 2008 | ASUS A7N8X-X Motherboard
Foxconn 661M03-G-6EL Motherboard Logo
150 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
