Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
Fuser thermistor fuser unit or lpc board
Where the loction of the Fuser thermistor fuser unit or lpc board and how to replace it
  • afax Dec 12, 2007
    Thank you for the help
    Novelist:
  • 208 Answers
The fuser thermistor makes contact with the heat roller. Normally they are in the middle of the roll.
If you are experiencing a fuser error. Most likely the upper fuser will need to be replaced.
Boards on faxes are mounted on the sides and base part of the frame
Posted on Dec 11, 2007
How do i fix the error code 6000 in kyocera 3060?
C6000 : Fuser heater break.
Fuser thermistor 1 detected less than
40°C/104°F for 10 s during warm-up and ready in.
Defective fuser heater M or S.
-Replace the fuser heater M or S.
Installation defectiveness on fuser thermistor 1.
-Check the mounting state of the fuser thermistor 1. If any problem is found, repair it.
Defective fuser thermostat.
-Replace the fuser thermostat.
Defective PWB.
-Replace the power source PWB or engine PWB and check for correct operation.
After parts replacement (fusing unit), you need to clear the fuser error code by going in the tech mode (10871087) and then U163.
Dec 19, 2015 | Kyocera Office Equipment & Supplies
MITA TA180 ERROR MESSAGE C6000
Fuser heater break
70°C/158°F for 10 s during warm-up and
ready in.
During warm-up, the temperature at the
fuser unit thermistor 1 does not rise by
1°C/1.8°F continuously for 5 s.
Fuser thermistor 2 detected less than
ready in.
fuser unit thermistor 2 does not rise by
Defective fuser
heater 1 or 2.
Replace the fuser heater 1 or 2.
on fuser
thermistor 1 or 2.
Defective fuser
thermostat.
Defective PWB. Replace the power source PWB or engine
Jan 08, 2014 | Kyocera Mita KM-1815 All-In-One Laser...
010-327 Fuser On Time Failure RAP
• After the Main Lamp turned On during warm up, the Control Thermistor did not detect
READY temperature within the specified time.
• After the Main Lamp turned On during standby, the Control Thermistor did not detect a
specific temperature within the specified time.
• After the Sub Lamp turned On during standby, the Control Thermistor did not detect a
• After the empty rotation started, the Control Thermistor did not detect the empty rotation
finishing temperature within the specified time.
• After the Main Lamp turned On during printing, the Control Thermistor did not detect a
• After the Sub Lamp turned On during printing, the Control Thermistor did not detect a specific
Initial Actions
Check for paper on the Fuser. The Fuser has no paper wrapped round it.
No)Remove the paper.
Yes)Check the installation of the Fuser Unit. The Fuser Unit is securely installed.
No)Install the Fuser Unit securely.
Yes)Remove the Fuser Unit. Check the conductivity of the contact points of the Thermostat. The
contact points are connected.
No)Replace the Fuser Unit
Yes)Check the resistance of the Main Lamp between P600-3 and P600-7 for an open circuit or a
short circuit . The resistance of the Main Lamp is 100 ohms or lower.
Yes)Check the resistance of the Sub Lamp between P600-1 and P600-7 for an open circuit or a
short circuit . The resistance of the Sub Lamp is 100 ohms or lower.
Yes)Check the resistance of the Control (Center) Thermistor between P600-5 and P600-6 . The resistance is 3k ohms or higher.
Yes)Check the resistance of the Rear Thermistor between P600-2 and P600-4 . The resistance is 3k ohms or higher.
Yes)Check the wire between J410 and J600 for an open circuit or a short circuit . The wire between J410 and J600 conducts with less than a few ohms.
No)Repair the open circuit or short circuit.
Yes)Check the wire between J6 and J600 for an open circuit or a short circuit . The wire between J6 and J600 conducts with less than a few ohms.
Yes)Check the wire between J401 and J523 for an open circuit or a short circuit .The wire between J401 and J523 conducts with less than a few ohms.
Yes)Replace the Fuser Unit . If the problem persists, replace the Power Unit . If the problem persists, replace the MCU PWB .
END
Aug 03, 2011 | Xerox WorkCentre PRO 128 Copier
Call for service.c440
Fuser unit error code, need to replace fuser unit
BR
Feb 11, 2011 | Toshiba e-STUDIO 352 Black and White...
Error code c440. call for service toshiba studio 352
BR
Feb 11, 2011 | Toshiba Estudio 200L Copier
MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Apr 09, 2010 | Copystar CS-1620 Copier
Fuser error 924.01
924 .01
Open thermistor check
failure. Fuser page
count between 0 and
99,999.
• Noisy thermistor signal.
• Intermittent connection.
• Thermistor cable not connected or
thermistor actually open.
Go to “924.xx—Hot fuser
service check” on page 2-91.
Error Code 923.xx, 924.xx, and 925.xx may display for a hot fuser failure.
CAUTION: .The fuser may be hot, use caution before removing or servicing.
CAUTION: There is a danger from hazardous voltage in the area of the printer where you are
working. Unplug the printer before you begin, or use caution if the printer must receive power in
order to perform the task.
Service tip: Set the Fuser Temperature to NORMAL before starting this service check. In Diagnostics mode, In
Diagnostics mode, select EP SETUP, and Fuser Temp.
1 Fuser assembly
Fuser to system board
cable
Check the thermistor cable for correct installation to J5 on the fuser
card. If installed correctly, check for correct installation of J10 on the
system board. If all cables are installed correctly, go to step 2.
2 Fuser top cover assembly
(thermistor/thermistor cable
assembly)
Turn the printer off and disconnect the thermistor cable from J5 on
the fuser board. Measure the resistance between the two pins on the
thermistor cable, if the resistance measures infinity (open circuit),
replace the fuser top cover assembly.
3 Fuser to system board
cable.
System board
Fuser assembly
Reconnect the thermistor cable to J5 on the fuser board. Disconnect
the fuser to system board cable from J10 on the system board and
measure the resistance between J10-3 and J10-4 on the cable. If the
resistance measures infinity (open circuit) check the continuity of
pins 3 and 4 of the cable. If correct, replace the fuser assembly. See
“Fuser assembly removal” on page 4-26. If incorrect, replace the
fuser to system board cable.
Note: If the error code still displays, replace the system board. See
“System board and inner shield removal” on page 4-76.
Most likely just replace the fuser (part of usage kit)
Enter Diagnostic mode:
1. Press and hold (Down Arrow) and (Up Arrow).
2. Turn on the printer.
3. Release the buttons when Performing Self Test displays.
Mar 29, 2010 | IBM Infoprint 1572 Laser Printer
Error code 021
Press
Function
7
monitor slowly 4 times
6
scroll down to SHIPMENT SET
set
wait for the fax to initialize and come back to READY
Sep 29, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
H3 ERROR CODE SHARP AL 1631
H3:
00:TEMPERATURE OF FUSER UNIT HIGH,THERMISTOR CONTROL BOARD FAILING
Did you replace the thermistor? check the thermofuse also for continuity
Oct 20, 2008 | Sharp AL 1631 Copier
I HAVE THIS CODE HOW TO RESET
C440:HIGH FUSER TEMPERATURE, OR LOW FUSER TEMPERATURE
Replace the Thermistor in fuser unit
Aug 24, 2008 | Toshiba e-Studio 350 Copier
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
672 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
