Question about LG VX5200 Cellular Phone
Blue screen got off an airplane turned on my phone blue screen
  • spartanlover Jun 10, 2008
    inside screen is blue outer screen is fine NEED HELP
Your screen is shot. You need to have the phone replaced. Blue screen is usually a bad ribboncable connection.
Posted on Dec 19, 2007
Turn off airplane mode
On what make and model?
Sep 06, 2017 | Cell Phones
Why cant i turn off airplane mode on a huawei m920
You can simply turn off or disable airplane mode by following these steps:
1. Press the Application Icon.
2. Then, click Settings and choose More.
3. Next, tap Airplane Mode to change the settings. Make it sure you`ve Unchecked Airplane Mode.
4. You can now go back to the Home Screen by clicking the Home Key.
Jul 06, 2014 | Huawei Cell Phones
Unable to acces network
Perform a hard reset on your device by pressing and holding your lock screen/power button until your device powers off. If this doesn't solve your problem please set your phone to airplane mode for ten seconds, and then turn it he airplane mode back off. Airplane mode can be accessed through your cell phones settings.
Thanks,
Dish Guy
Apr 07, 2014 | Nokia E Cell Phones
When i am talking on the phone, it goes to airplane mode and i cannot use the phone...how do i fix or lock the screen or get the airplane mode off of the quick touches
This will help to reduce the frequency of this issue occurring. I have the same problem and have not yet found a way to remove the Airplane Mode option form the action bar pull-down for the Z998 phone. It is a ZTE firmware issue, not Android.
UNDERSTAND WHAT HAPPENS: when the phone moves slightly away from your ear while talking, the proximity sensor detects that it is not close to your face and it turns the display back on as it should. The screen often comes on with the action bar pulled down and thus all the controls exposed. A moment later your phone touches your ear before the proximity sensor had caused the screen to go blank again, so whatever your ear touches, can become an actual user command, even though unintentional. Unfortunately the Airplane Mode is one of the first selectable options on the Action Bar. You might sometimes notice that Bluetooth, Sound or Mobile Data gets toggle also; at least that does not cause you the dropped call. The problem gets worse when you walk or move around or fidget a lot while talking.
THIS HELPS: manually turn the screen off (press the power button) after you answer the call. Because you deliberately power off the screen, the proximity sensor is bypassed. The job of the proximity sensor is to turn on/off the screen to save battery (the reason of course that when the phone is against your ear, you cannot possibly also look at the screen, hence the proximity sensor turns it off for you). You will soon get in the habit.
Apr 01, 2014 | AT&T GoPhone Z998 4G
Remove flight mode
Turn on / off Airplane mode
Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls.
To turn on airplane mode, follow these steps:
  1. From the Home screen, select Go to.
  2. Scroll to and select Profiles.
  3. Scroll to and select Flight.
  4. Select Activate.
To turn off airplane mode, follow these steps:
  3. Scroll to and select Normal (or a profile other than Flight.)
  4. Select Activate.
Jan 04, 2014 | Nokia Lands Phones
I just got my new htc desire and by accident turned on airplane mode and now dont know how to turn it off
Go to "Settings->Wireless & networks" and then uncheck "Airplane mode". If you added the "Airplane Mode" widget on your home screen, just tap it again to toggle.
Jun 27, 2011 | HTC Desire Cell Phone
What is airplane mode and how do i get out of it??
Airplane Mode (Motorola CLIQ™ with MOTOBLUR™)
NOTE: Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls. An Airplane icon appears on top of the signal bar when airplane mode is active.
To turn Airplane mode on or off, refer to the following:
Using the Lock key
To use the Lock key to turn off Airplane mode, perform the following steps:
1. At the Home screen, press and hold the Power/Lock key on the right side of your phone.
2. At Airplane mode, tap On or Off.
Using the Settings menu
To turn the Airplane mode on or off using the Settings menu, perform the following steps:
1. At the Home screen, press the Menu key.
2. Tap Settings.
3. Tap Wireless controls.
4. Tap Airplane mode to turn on or off.
Dec 04, 2010 | Motorola Mobility CLIQ Cell Phone
How do I get my LG Ally off airplane mode
Press the menu button then press settings on the screen. Press wireless networks at the top of the listing then uncheck the airplane mode setting. This should turn off airplane mode on your phone.
Oct 21, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Cant get off airplane mode
you have gone through the following?
settings > wireless controls > airplane mode
if this doesn't work, try this:
hold the red end call button until the phone options menu appears. try turning off airplane mode.
add the airplane mode widget on your screen by pressing + > htc widget > setttings > airplane mode. try turning it on and off with that.
if not, then i have no other suggestions for you other than take it into a store to get it looked at.
good luck.
Dec 04, 2009 | HTC Hero Smartphone
Screen does not light up
you turn on airplane mode by holding the on/off button too long when turning it on. no more that 5 seconds. tough to take the screen apart, go to a nextel store, they have the tools.
Dec 16, 2007 | Motorola Mobility i860 Cellular Phone
LG VX5200 Cellular Phone Logo
469 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
