Question about Philips Magnavox 51MP392H Rear Projection Television
Play for 1Hr then short out Hor out tran 2SD1556
Bought a not working Magnavox FP5230 W102 Chasses No. PTV620-AH01. Plug up and will not come on, found a shorted Hor. Uotput Tran. 2SD1556 replace and played for about a hours then just blank out. Hor Output shorted out again. Any ideal, you can post as technial as you want, have mulmeter and know how to used it and solder iron.
    President:
  • 4,402 Answers
If horz output keeps shorting then the high voltage flyback is bad.
Posted on Dec 11, 2007
My Philips Magnavox 60 in rear projection TV # PTV775-AH01 has no power when you turn it on. How can I fix it?
It sounds like a power supply problem, it could be as simple as an internal fuse (not the fuse in the plug) or something more sinister like a transformer issue which can become expensive, either way i wouldnt recommend repairing yourself unless your confident with electrics and know what to look for
Oct 28, 2014 | Philips 60P8341 60" Rear Projection...
Service Manual needed for a Magnavox Rear Projection TV Model # 6P6040 W102
too old--only available to authorized service centers and online---what is issue with this set?
May 14, 2012 | Televison & Video
I have a 52 inch Magnavox Model FP5230 W102 that the picture just quit are there fuzes or resets
WELL IF YOU HAVE ALLOT OF TIME ON YOUR HANDS,I'M GETTING READY TO RESOLDER THE MAIN BOARD, EITHER IT WILL WORK AND SAVE YOU MONEY OR TAKE IT TO THE SHOP.CHECK TO SEE IF THE WARRENTY IS UP....LOL THE TV'S TODAY ARE NOT THAT BAD $$$$$ I THINK THAT ALL DO.
Oct 12, 2011 | Philips Magnavox 51MP392H Rear Projection...
Blurry picture
You need to clean the projector lens on the optical engine using a soft cotton or, better yet, a chamois cloth. Also clean the mirror mounted inside the rear cabinet and also the front and rear of the screen itself.
If picture is still blurred then your the optical engine is most probably defective.
Dec 10, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
MAGNAVOX 50 INCH REAR PROJECTION Hor. Output Tran Keep Going Out
Try checking some of the tunning and coupling capacitors around the horizontal section as well for some crystalized solder joints in that area.
Jan 06, 2008 | Philips Magnavox 51MP392H Rear Projection...
Remote Control for Magnavox Big Screen TV (PTV 705-AH01)
sgtdar, list the model & chassis number (located on back of tv), if set is old the universals won`t work because as more newer sets come out they delete the older ones because the chip in the remote will only hold so many codes, BMW Rider
Dec 12, 2007 | Televison & Video
Loud pop and picture is no longer available.....
blown resistor (42ohm) replaced this and it imediately blew it clearly shows that there is a short circuit in your tv. if you are a tech person please proceed as follows. 1 isolate power supply from hor.output section. 2 now check power supply section.i.e. switching tran., cap..diode etc. 3 if it becomes ok check power supply output. 4 if output is ok then check hor. output section.i.e. h.out tr.,cap& diode in eht winding. 5 check print near eht. 6 at finally eht. 7 see every thing is normal now. now reconnect power to hor.section. put on tv. good luck.
Sep 24, 2007 | Philips 7P6041W TV
Lg 5552 v set is dead
try to resolder all points in fbt including fly back trans itself area also resolder the crt pcb area i had the same problem the reason was cold soders also put a good 2sc5297 for hor out.
Dec 02, 2006 | LG Studioworks 552V 15" CRT Monitor
Philips Magnavox 51MP392H Rear Projection Television Logo
79 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
