Question about Kenwood DDX7019 6.95 in. Car Monitor
Rear view camera setting???
I have a rear view camera - Boyo vtil200 it is a chrome small camera that goes on the license plate frame. It is connected but, how do I go to the camera set up on the Kenwood deck?? I put the car in reverse but, the camera doesn't go on.
  • 38 Answers
Re: Rear view camera setting???
Dear debbie,
This could be caused by the following:
Purple/white "reverse sensor wire" not connected to vehicles reverse lamp harness. (Are your reverse lamps functioning?)
Reverse cam video out not connected to Kenwood's "rear view camera input" (Yellow RCA socket behind the unit).
The monitor set up controls merely switch R-cam betwen "full, just, zoom and normal" modes. No provision here to ebnable or disable the cam.
When you put your car in reverse dos the monitor screen change?.
Posted on Mar 09, 2008
0 characters
3 Points
Where to buy a Replacement TouchScreen for my Jensen UV10
You can try going to and see if you can contact them that way. Jensen is now owned by audiovox.
Aug 31, 2012 | Jensen Uv10 7" Lcd In Dash Car Dvd Monitor...
Getting a blue screen from rear view camera, worked fine until today
Blue screen is generally no signal from camera, possibly broken camera feed wiring or bad connection, if the camera is on a tailgate, breaks occur where the wiring leaves the tailgate to th car body, good luck.
Aug 27, 2012 | Car Video Monitors
What to do with the second camera wire? Video connection and...? Pyle PLCM 7200
This is not a solution. I have the same question. In addition, my unit shows blue screen and "no signal". Any guesses?
Jun 24, 2011 | Pyle PLCM7200 Car Monitor
There is a black power cable with two leads for the power for the camera but I don't have in the instructions what to do with it
This is how to hook up the Pyle PLCM7300BT:
On the license plate camera, plug the black cable provided with 2-wires inside (one red and one black) to its counterpart on the camera. On the open end of this black cable, strip and connect the black wire to the car/truck metal body part.
Connect the red wire from the camera and the green wire from the monitor (part of the big black cable from the monitor) to the power wire to the back-up lamp socket.
Connect the Red wire from the monitor to a switched terminal on the fuse box so that it would only have power when you have the ignition key on.
The rest of the wiring is simple and common sense.
To operate, turn on the ignition of you car/truck and put it on reverse you should see the camera view. Put the car/truck on Park, the monitor screen should go back, if not, push the power button once.
To set up the blue tooth: Push the power button on the monitor so that you can see the blue screen and "no Input". Put your phone on discoverable mode and push scan for device. AT the same time push the "pair" button on the monitor.
I did all the figuring out on the bench using a 12 VDC power supplies and contact switches to make sure I understood how it worked. Once installed on my 1988 Suburban, it worked as expected.
The only problem I had to patch the long green wire (reverse car) so that it reached the back-up light socket.
Let me know if you still have problems. Email me at
Wayne Tan
Feb 24, 2011 | Pyle PLCM7300BT Mirror Monitor
How or where do I hook up the green wire (the one going to the reverse whatever),,,,,..... I would like to hook it up so it only comes on when the car is in reverse and becomes a mirror all other...
I added some extra line and hooked it up to my trailer plugs' light green wire. I also connected it to the tail light solid green wire. Both produced current the same way. Still blue sreen with no signal...but I am sure this s where to plug them.
Oct 19, 2010 | Pyle PLCM7200 Car Monitor
Have put on a reversing camera and it work a treat. Only problem is that as soon as I start to move backward the pitcher disappears. Is there something that can be put into place so that it stays on??
you can not view a screen while your driving its against the law. there is a wire that is connected to your shifter that tells the monitor to turn off and on. find that wire and ground it and the montor will stay on all the time. why would you want a rear camera on all the time anyway?
Sep 06, 2010 | Blaupunkt Car Video Monitors
How do i install the visors in my dodge stratus 2000 SE 2.0, and where exactly do i connect the power cords to to get the power to get them to work, and how do i connect them to my car video stereo ? if u...
connect the red wire to the red/white wire here is the wiring diagram
2000 Dodge Stratus Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Yellow
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Orange/Brown
Car Stereo Dimmer Wire: Black/Light Blue
Car Stereo Antenna Trigger: Orange/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
pls rate
Aug 17, 2010 | Pyle PLVSR72GR Sun Visor Monitor
The rear camera have two wires: one is Video AV2 and the other is black/red color, OK. Now, my question is:Where to connect the black/red wire? Thank you.
This is the power connection.
You need to connect this to a 12v switching circuit to enable the camera to overide the current display.
For example, you could attach it to the reversing light switch in the gear box so that when you select reverse the picture is over ridden with your camera view. Or to the reversing lamp. You could connect it direct to a switch for manual control.
Mar 23, 2009 | Car Video Monitors
Xo vision XO1943BT
Aug 25, 2008 | XO Vision MD068 6.8 in. Car Monitor
Back A Car Signal
The speculation on this webpage: makes it sound like it is a trigger to switch the monitor to display a rear-facing camera when you put the car into reverse. You would either wire it to a manual switch (to 12v) or to your reverse lights. Keep in mind, this is not an authoritative answer. Good luck, and let us know if this helps!
Mar 20, 2007 | T-View T700HRBK 7 in. Car Monitor
Kenwood DDX7019 6.95 in. Car Monitor Logo
1,430 people viewed this question
Top Kenwood Car Video Monitors Experts
xxxxxx xxx
David Burbee
David Burbee
Are you a Kenwood Car Video Monitor Expert? Answer questions, earn points and help others
