Question about GE Energy Star WCVH6260F Front Load Washer
GE Front Load Washer Model#GCVH6260F-Problem with no washing, spin or aggitate function but motor works fine...
The washer will process the water and advance into the wash cycle but then does nothing-no wash, aggitate or spinning of clothes. It will drain the water and the motor is fine. We thought it might be a filter problem (as it likes to eat my childrens small socks and we have had this problem before but this is not the case). Any suggestions?
  • 2 more comments
  • Steve Guillen Dec 11, 2007
    I turn on washer the lights light up I press start and it make the start sound but it don't start
  • ABA477 Jan 20, 2008
    Help!! The water comes in and there is no spinning... the timer counts down and the water drains out. It cant be the motor because the drain and spin cycle sometimes works. Also when I start a cycle, the door locks and the drum spins twice and then the door unlocks and then re-locks and then nothing nothing!
  • ttider22 May 08, 2008
    My G.E. washer does the same, Locks door turns to the right one time, turns to the left one time,adds water and does nothing else until its time to add water again, it adds more water and eventually pumps it out but no wash or spinning. clothes are soaked when taken out.
  • Anonymous May 19, 2008
    My GE front loader would get to the last spin and wouldn't finish.  The start/pause button would light up.  I took off the front panel and cleaned out the filter.  Cat hair and a baby sock.  Everything is fine now.
Also helps to remover the whole rubber piece connecting the filter and drains together, mine was filled with alot of grit and even a ball point pen!
Posted on May 09, 2008
Right on!
Thank you so much for the help!!!!
Posted on Apr 19, 2008
Try cleaning out the filter - it's behind the bottom panel (three screws to remove) you will see a round disk - unscrew it and pull out the filter. I have to clean ours every six months - it's too bad GE didn't put it in their manual, that this needs to be cleaned periodically.
Posted on Apr 18, 2008
I have a Whirlpool washer WFW9050XW00 that stops during the wash cycle. The machine beeps and the wash light flashes 9 times pauses and flashes 1 more time. Thanks in advance
My Washer stopped while washing and will not spin drain or aggitate.
It will power on and off I can change the settings but nothing happens.
Oct 26, 2013 | Washing Machines
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
I have a Sears Kenmore washer that sometimes does not spin in the spin cycle and sometimes it does. The timer progresses to stop, but clothes are still dripping wet. Resetting timer from spin usually...
The transmission in this machine is worn and is not shifting correctly. Understand that after the aggitate cycle, this machine should go into drain cycle without spinning and it should drain for about 1 minute. Then it should kick into spin cycle after it has emptied all the water. What is happening is it is (like skipping) the drain cycle and going directly into spin with water still in it,,, so the spin is slow as it is trying to empty and spin at the same time,,, thus the clothes do not spin out correctly,,, when you reset the spin, you actually spin all the water out the second time around.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Water fills the tub then nothing happens.
it does not aggitate? Thats the cycle that allows the water to wash the clothes. It may be broken, I have had that happen a couple times. I would take the aggitator off and see if the teeth in the groves are worn out, It happen's when used alot. Commen problem and easy to replace.
Apr 05, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
Whirlpool Washer wont spin or drain
check your run capicitor
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 01, 2008 | Washing Machines
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Oct 29, 2007 | Whirlpool LSR5132PQ Top Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
316 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
