Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Loud Fan Noise
I have owned my 42" Wega for almost two years and this past weekend the fan became noisy. I had never heard the fan before a couple days ago and now it is loud enough to be heard over the volume of the tv. How do I get the noise to go away and prevent it from returning in the future? If you recommend some basic maintenance, can you specify whether it could be potentially damaging to the tv if I make a mistake? How do I clean the fan, if necessary? How do I determine the temperature of the tv to see if the fan is working harder to bring the heat temp. down within the tv? Any help would be greatly appreciated. Please advise.
    Problem Solver:
  • 8 Answers
The noise is most likely a colour wheel it is next to the lamp have it looked at. it is run by ball and bearings if you shut off the tv and it starts to wind down it is definatly the COLOUR WHEEL
Posted on Jul 14, 2009
  • 4,402 Answers
This is a free repair on the optical block/engine. For specifically a road mapping issue. (Where there is sparactic grouped lines on the screen of the TV)
Otherwise there is a full recall on all 50XBR1's and 60XBR1's for ANY video issue.
But the bullentin I do have on that is Confidential due to the amount of claims SONY could recieve. But here is a sample of the bulletin.
Models: KDSR50XBR1, KDSR60XBR1
Subject: Optical Block: Warranty Policy and Part matrix by serial number.
Resolution: As part of Sony’s commitment to quality, Sony is announcing that it is extending the limited warranty (parts and labor) for optical block replacements on the models listed above until October 31, 2008, regardless of purchase date. Authorized servicers should follow the normal process for warranty claims for this issue.
Posted on Dec 11, 2007
Noisy fan and no heat
Kitchen aid is made by Whirlpool. There is a very good chance the then thermal fuse on the back of the oven has tripped. Whirlpools are very prone to this fuse tripping after a clean cycle. The noisy fan is just that a noisy fan it will probably need replacing. I have replace a couple of them over the years. When you pull the oven out to replace the thermal fuse replace the fan motor at the same tiome.
May 06, 2014 | KitchenAid KEBC207 Electric Double Oven
Noisy fan on sony grand wega tv
If it is the Fan Part# is 1-787-057-11 DC Fan.most of the time you can pull back and if fan is ok color wheel will make noise when going Bad.
Sep 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Hi, we have a humming sound that is really loud,
Yes, its fan noise and you need to replace noisy fan.
Let me know exact model of your Sony TV and need to know what fan is producing noise to provide you part number and parts shop info to buy that fan.
Jul 31, 2009 | Sony Grand WEGA KF-50WE620 Television
Sony 42" Grand Wega makes noise constantly when running
That is correct, it would be fan noise and fan will be replaced.
Let me know exact model number to help you in finding fan in parts stores.
Feb 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have owned a Sony Grand Wega for about 3 years now and for the past few months the TV has been making a very loud noise. I thought the noise was the fan but came to find out it was not the fan and was...
There is a fan beside the lamp chamber in this TV. There should be 4 fans total, and the one beside the lamp chamber might be making some noise. They are all bearingless fans, so the noise should be relatively low-pitched "whirr" if it is the fan. If the noise is more of a buzzing sound, it could be coming from the lamp driver (ballast) or from the lamp itself. Lamps tend to do strange things toward the end of their life.
If you have never changed the lamp, it is about time. They have a 2.5 -3 year life span with average use.
One thing you can try is to turn the TV on from a cold start, and watch inside the vent areas beside the lamp chamber. If you hear the noise before you see the lamp light up, then it is probably a fan. If it starts as soon as you see the lamp light up, it is the lamp or ballast.
Hope this helps you...
Jan 06, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony 46'' WEGA TV
The mirror assembly has no moving parts, this unit has a minimum of 3 fans! if the fan blades get too dusty the fan will get noisy. Try cleaning the fans with compressed air.
Jan 04, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Excessive Fan Noise
If I may - - the Grand Wega has a common color wheel problem and it may not be the fan at all... If while you are powered up listen carefully to the noise as you hit the power button - does the noise go away or is it still there? If rough noise stops and you can still here something in there running at a whisper then your problem is a bad color wheel not a fan... If it doesn't stop and it is the fan you'll most likely need to replace it.. Like Lemmor said you may need to clean your air intakes, which you can do with the hose on your vacuum but that is a brushless fan and no oil change in the world will help it..
Dec 11, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Noise Problem
Is it a frost free freezer ? if it is it sounds like the evaporator fan motor making the noise
Aug 29, 2007 | Danby 16.7 cu. ft. / 473 liter Upright...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
191 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
