Hotpoint 18 in. DC27 Slim-Line Built-in Dishwasher
Problem for Hotpoint 18 in. DC27 Slim-Line Built-in Dishwasher
Dishwasher pump will drain but not force water into spray arms
By bobschwind on Dec 11, 2007
when i turn on dishwasher, it fills then nothing. it seems to go through all cycles but water not pumped into spray arms. spray arms not clogged. it's a kitchenaid "c" model. water will then go through dry cycle and drain so that pump is working. is there a 2nd pump to force water into spray arms? dishwasher just hums when "wash" cycle is on. could this be a pump problem? could it just be clogged at the intake of pump? suggestions what to check would be appreciated.
Same Problem
Feb 12, 2008
-   I'm having the same problem with my Fridgedaire 18" built-in. There was some load noises coming from pump area off and on followed by no water being forced into the tub, through the arms. I'm not certain ,but does it sound like I need to replace the pump motor assembly, or is there another less cost affective way to fix this? Any help would be appreciated.
Bryan-   crash01
Best Solution
posted on Feb 09, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If the washer is not used regularly the shaft can stick to the seals and prevent the motor from spinning. This happens quite regularly for me if I don't use the washer often. You can just take off the bottom panel - after shutting off power to the dishwasher - and access the motor. you should see some fins and then just try to spin the motor by hand. It usually takes about 90 degrees of rotation before the motor breaks free from the seal. You'll have to fight through the spring-like resistance created by the seal-shaft adhesion. After it breaks free the motor spins freely and you should be all set to go. I haven't found a more permanent fix for this other than running the dishwasher more regularly.
Solution #2
posted on Dec 11, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hi there is a scond motor that forces the water through the spray arms it sounds like the motor has seized .
Popular Solutions for Hotpoint 18 in. DC27 Slim-Line
Questions and Unsolved Problems for Hotpoint 18 in. DC27 Slim-Line
Do you recommend Hotpoint 18 in. DC27 Slim-Line Built-in Dishwasher?
Answer
Answer
will not drain full small amount of water left in bottom of machine
Answer
water will not go into machine even though supply is ok (i'm a plumber)
Answer
prewash and wash light was flashing now when I put dishwasher on the prewash light goes on but no... (More)
Answer
Water is not getting to the spray arms. I have checked the spray arms and they are not blocked. And... (More)
Answer
My Hotpoint DC27 will not fill with salt properly & I have to put it in every time I use it - it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
