Question about Saeco Magic De Luxe Espresso Machine
Part 2 -Flashing water light - will drain water but will not make coffee
Thanks for the tip johnnybeans, I tried that last night, and apparently my grinder is working because I had the same result. The low water light started flashing again after it failed to dispense anything, so I drained it out the hot water / steam nozzle. Any other ideas? It must be something with water specifically for coffee.
  • Anonymous Mar 04, 2008
    Water light is flashing. Have drained tank. it will drain water but will not make coffee. Before I could drain some water out and the light would go off, but now the light continues to blink.
    Scholar:
  • 67 Answers
Blinking light often means pump is not delivering water. Possible blockage from corrosion. Can also mean a valve blocked.
Do you hear the pump run?
Posted on Mar 14, 2008
Mr. Coffee single serve brewer won't brew
First clean and please try again
Fill the reservoir with water.
Place your mug underneath the machine.
Add the K-Cup.
Choose your serving size.
Press the brew button to begin brewing.
Enjoy your delicious cup of coffee! .
Sep 25, 2013 | Mr. Coffee BVMC-KG6 Single Serve Coffee...
My coffee maker went from making a perfect cup of coffee to a flavorless cup over night. I use bottled spring water. It does not say it needs descaling. I drained the machine and still the coffee is...
Hi, The bottom needle is plugged.... this causes the water to flow back up out the top of the cup rather then flowing through the cup...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 05, 2011 | Keurig Elite B40 Coffee Maker
My Keurig has not been filling up the cup all the way lately. Last night the descaling light came on. We put white vinegar in it, ran it, and then water. Now it is not working at all. The machine is...
Sometimes the descaling sets off another whole set of problems...
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Mar 24, 2011 | Keurig Platinum B70 Coffee Maker
Dishlex global 300 dishwasher, eco light flashing sounds like pump noise but not working
Try taking the dishwasher out of its wall space and tipping it back and forth. Apparently the weight of water gathering in some component triggers the 'eco' function. Failing that, last time it happened to my dishwasher i waited a week for the repair guy to arrive, by which time the water had evaporated and there was no longer a problem..
Jul 26, 2008 | Dishwashers
Both the intake and drain lights are flashing
There are several simple solutions, one is reading the instruction manual. Check Intake: is any water entering? is it slow? This machine filters debris from the supply water so check the water intake filter. It is inside the end of the intake hose end against the home. Rinse it clean.
Drain: The same fault appears if the drain is clogged. Check if the lint trap is perfectly clean. Check the impeller (a set of fan blades) behind it spins freely. If buttons or coins get in there they can break off the fan blades and you can't drain water. Check the end of the drain hose if it drains. put it into a bucket or tub basin to observe how strong it pumps. Call Miele if these tips don't work. Be at the machine with Model and Serial number ready.
Dec 16, 2007 | Miele Touchtronic W1113 Washing Machine
Saeco Magic De Luxe Espresso Machine Logo
250 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
