Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Clicking sound coming from the icemaker
There is a clicking sound coming from the ice maker. I took off the panel and underneath is basically a wheel that turns in one spot and clicks. The wheel says do not rotate manually. The ice maker is making ice.
  • jb24 Feb 05, 2008
    I have the same problem. The plastic wheel is slipping on another gear....
  • 126 Answers
You said it is making ice but is it ejecting the ice if not the heater could be bad if this is the case replace ice maker
Posted on Dec 11, 2007
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
Ice Maker Failing to Eject Ice
icemaker not making ice video-
Nov 23, 2014 | GE Refrigerators
No water to the ice maker .I took out the cover of ice maker turn by hand the wheel after one cycle .I heard the sound and water filling up ice maker but when it become ice for long time .the ic
Hi friend, thanks for your post!
I understand that your icemaker on your Frigidaire refrigerator is not getting water to the icemaker. It sounds like you could have an issue within the valve or solenoid. I would recommend having a professional come out to properly diagnose your appliance and repair it. -Matt
Sep 17, 2014 | Frigidaire Refrigerators
Subzero 690 ss icemaker making a clicking sound why
If the noise is coming from the ice maker head itself. Then it sounds like the gear is slipping. They are plastic and it is very common for them to crack or break. Most ice makers are the same. Click Here to see a post on a Whirlpool ice maker with a broken gear.
Good Luck From David at refrigerator repair.
Apr 04, 2013 | Refrigerators
Ice Maker stopped working
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jun 07, 2010 | Maytag 18.9 Cu. Ft. Top-Mount Refrigerator...
Our GE side by side fridge isn't making ice. The arm in the ice maker starting clicking in the middle of the night and my husband just went into the freezer and held the arm up for a few seconds. The...
It sounds like you have a bad icemaker. Usually when the arm is clicking its the gears that are stripped out. Feel in the icemaker if theres cubes frozen in there then you know the icemaker is definitely bad. With the arm in the up position it will not make cubes at all that is the off position for the icemaker. Hope this helps _MJ_
Apr 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker doesn't work. Makes a clicking sound,
Ice makers in refrigerators are one of those things that fall into the category of, "use it or lose it". The clicking might be the solenoid trying to open. the valve might be clogged or bad. It could also be the auger motor turning but the shaft might be broken or somehow disengaged.
I'm not a fan of refrigerator ice machines and never recommend getting one as an option because they are junk. Once they break you can't simply remove them because all refrigerator functions run through them. Home ice machines are cheap and work forever and they have nothing at all to do with the fridge. Those I like!
Jul 09, 2009 | Refrigerators
Samsung rf267aars icemaker stops making ice, icemaker makes clicking noise.
unfortunately it sounds like you have a broken tooth on the drive or driven gear of the ice maker, in this case you should replace the ice maker. The good news is that you can get a new one for about 85 bucks at your local appliance parts store.
Jun 23, 2009 | Samsung RF265AA Bottom Freezer French Door...
Ice maker not turned on or hooked to water line
it my be not the icemaker check fan or you can remove icemaker
Feb 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice Maker Making Noise
sounds like your icemaker is jammed.
first ofall just feel around the icemaker and see if you can find a peice of ice jamming it that you can remove. if that doesnt work heat it up with a blow dryer until any ice that is there will melt away and it will free up..
there is one other possibility: the stripper could be jammed against the side of the icemaker in which case you'll have to remove the icemaker from the refrig and unjam it..
hope that helps and good luck
Dec 15, 2007 | Jenn-Air JBL2086HES Bottom Freezer...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
172 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
