Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Flash will not pop up
My flash will not pop up and when I get it to come up the flash will not work. Any suggestions?
  • markscott Dec 18, 2007
    Read manual, tried many buttons, re-set all. but no matter what I do the flash unit will not pop up.
    Scholar:
  • 152 Answers
If it is really old, the bulb could be busted...
other whise, if its digital, there must be something wrong with the setup..
Posted on Dec 11, 2007
Nikon D5100 camera flash does not pop-up. Any suggestions?
You can't pop up the flash in the Auto mode. In this mode the camera decides whether to use the flash or not.
Try switching to one of the PSAM modes. Does the flash then pop up when you push the flash button?
Jan 17, 2014 | Nikon D5100 Digital Camera
Nikon D90 flash will not pop.
I suggest you take your camera to a Nikon camera repairer.
Apr 18, 2013 | Nikon DSLR D90 Digital Camera
Canon EOS Rebel T4i 650d flash pops up but does not work.. Camera is 2 months old any suggestions please
I suggest you return the camera back to the shop and get the camera repaired or replaced as it would be still under warranty.
If you try to fix it yourself you may void your warranty.
Feb 22, 2013 | Canon Cameras
Canon d60 - Built-in flash will not pop up
There may be something obstructing it from popping open. Inspect the flash area carefully. You could remove the battery and put it back in to see if it corrects the problem. Also, check the flash settings in the menu to make sure that the flash is set to operate. If all of those fail then take the camera in for warranty repair. If the warranty has expired and nothing else works I would suggest getting an external flash for you camera. You will be amazed how much better your photos come out using an external flash. If you go that route then I would suggest going to a camera shop or department to make sure the flash will work for you before purchasing. If you just want a small flash a little better than the built-in, get the SB400. It's only around $125. The SB600 is much better, but will cost almost twice as much (but I think it's worth it).
They work beautifully in auto, but the SB600 will reach much farther and give you less red eye. Good Luck you have a great camera!
Nov 10, 2009 | Canon PowerShot EOS D60 Digital Camera
Flash
mcomijohns. WHAT ARE YOU SUGGESTING!!!! Stop.
Lakshmy Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it pop up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.) PLease let u shave more information for a proper solution.
Sep 26, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
My Rebel T1i's built in flash stopped working after I used a 580EX external flash on it. It won't even show up on the LCD screen.
Really? the best solution available is to take the top of your camera off?
i don't think so.
Here's a very simple solution I found to get the flash to pop up without destroying your camera.
http://forums.dpreview.com/forums/read.asp?forum=1031&message=31993875
the person suggests using a fingernail. (s)he must have long fingernails. I had to use a piece of paper folded in half. Swipe the paper from back to front, as in, from the eyepiece side towards the lens side.
Here's a picture: http://www.flickr.com/photos/dougpardee/133066175/
good luck
Sep 25, 2009 | Canon EOS 500D / Digital Rebel T1i Digital...
Nikon SB-80DX doesn't work
The symptoms and sounds you describe (pop, now rattling) point to the flashtube being blown. Sorry. You can get a repair estimate, but you may find it cheaper to buy a used on on eBay or craigslist. Around $100-110 on eBay if you are patient.
Dec 10, 2008 | Nikon Speedlight SB-80DX TTL Flash
Pop-Up flash - Rebel xti
You will need to send the camera for servicing. There's a lever mechanism inside the flash unit which is responsible for popping up the flash. Since it is a mechanical device, it is sometimes prone to failure. I suggest not to put manual pressure to force the flash to come out, as it may cause permanent damage. Instead, send the camera for service.
Dec 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
