Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Wega TV will not recieve cable signal all other modes work in video? all other tvs work with the cable. was wacthing one day and tv went snowy and a caption came one no cable signal
  • 4,402 Answers
Have you tried an external antenna?
Posted on Dec 11, 2007
  • Cary Farah
    Cary Farah Dec 11, 2007
    Check the Cable setting in the Channel Setup menu
I have no picture.
Just a thought from out of date tv user. Make sure there is power at outlet. If you have cable or antenna connected, make sure it is set to the right mode. One mode is all the tv channels, another is simply a second imput like vcr, and may have a third mode for games etc. On mine, each mode is specific to a set of terminals (yell/red/wht) on the tv back side (3 sets of terminals back there with each used with one mode), if in the wrong mode won't connect with input signal. Switch tv on then find the mode switch and try each one to see if you can get a picture or even snow. May also have some auto feature that if signal isn't detected, it won't startup the big screen (so you don't get blast of loud sound and snowy picture), try a spare tv on the input signal to see if the input signal is there and working. Hope that helps.
Jan 13, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Screen suddenly went to complete snow no video or audio
Well the LG tv is not getting the cable signal.Unplug the cable box about an hour.Replug the box let the software to upgrade the cable box.The LG tv should get the signal back as normal.Not,than the LG tv Tuner board have problems it dead.Tries Websites like, to buy a refurbish Tuner board for the replacement.
Apr 21, 2010 | LG 32LG30 32 in. LCD HDTV
No signal and theres signal
sounds like you need a new tuner replaced or the ssb(small signal board) inspected. The tuner recieves the cable signal and converts it into an intermidiate signal which in turn the ssb processes into audio and video signal.
Sep 09, 2009 | Sony Grand WEGA KF60DX100 60" Rear...
Lost some stations on my Sony lcd TV.
It is most likely a signal issue. Bad coax connections, splitters and faulty cable are usually the culprit. Best to call your cable company and request a signal test. You may also try swapping tvs. Swap sony with viewsonic in the room where viewsonic tv is.
Jul 03, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
No digital to reciever??
This tv will only output the sound from a digital tv channel through the optical output when using the tv's digital tuner. So if you are connecting a DVD etc it will not output through the optical output on the tv. ONLY digital chanels through the tv's tuner will give you sound. Refer to the tv's owners manual for more info.
Dec 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony tv problem
If you are connecting the dish receiver to the standard antenna jack (F connector) on the TV, then the TV must be in TV mode and tuned to channel 3. If you accidently change to another channel then you will get the "no signal" message. If this is the case then simply put the TV back on channel 3. If you are using the RCA jacks (red, white yellow) to connect the dish receiver to the TV, then the TV must be in the VIDEO mode to work properly. If you accidently put the TV in the TV mode, you will get the "no signal" message. If this is the case then simply press the TV/VIDEO button.
Sep 18, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
"No Signal"
Might need a tuner, I suspect if you arent seeing any snow/static you probably need to press the tv/video button untill you get the ANT input.
Jul 31, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
186 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
