Westinghouse LTV-19W3 19 in. LCD Television
Problem for Westinghouse LTV-19W3 19 in. LCD Television
TV turns itself off, and then switches back on with no display
By jmarkus on Sep 13, 2009
It seems the power brick gets very very hot, but sometimes it turns off within minutes while the brick is still cool? Can a third party power supply fix this, or is it internal?
Solution #1
posted on Sep 14, 2009
Not Rated)
roety
Rank: Guru  Televisions & Videos  Expert
Rating: 90%, 173 votes
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like an internal TV issue , only way to know is replace the power supply brick.
There are a few boards in the Tv none that are easy to buy, I'll bet you can buy a replacment power brick on ebay for less than $30.
If you do open the Tv look for any capacitors that look bulged or swollen.
example
If you feel good about my solution please click accept.
If you have more questions post them and
I will reply asap
Thanks
Was this helpful?
Yes
No
Solution #2
Not Rated)
trytom
Rank: Master  Televisions & Videos  Expert
Rating: 100%, 7 votes
Its normal for the 'brick' (power supply) to get hot, the power supply would not be the problem here as if it was faulty it wouldt power the screen at all, I guess you have a small 15" LCD TV which runs on 12V? The problem would be internal, Hitachi TVs have this problem, its normally down to a small capicitor on the main board. Speak the manufacturer for more info.
Was this helpful?
Yes
No
Popular Solutions for Westinghouse LTV-19W3 19 in.
Questions and Unsolved Problems for Westinghouse LTV-19W3 19 in.
Do you recommend Westinghouse LTV-19W3 19 in. LCD Television?
Answer
Answer
tv will not turn on. Changed battery in remote. Still no power
Answer
My LG 42 flat screen tv switches itself to different modes and even turns on and off. Is it a sensor... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Westinghouse LTV-19W3 19 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
