TLP 2844-Z doesn't print label barcode in 30 x 1,5 mm I have installed Zebra Designer to make a...
(More)
TLP 2844-Z doesn't print label barcode in 30 x 1,5 mm I have installed Zebra Designer to make a barcode in a paper with this specification: single label 30 mm Width 15 mm Height every rows are made by 3 label (horizontal) with 100 mm Width 2 mm Left Margin 2 mm Right Margin 3 mm X Gap 1,5 mm Top Margin 1,5 mm Botton Margin infact 3 x 30 + 2 + 2 + 3 + 3 = 100 mm = Row width the problem is when i try to print this label the number of the feed is right but the label are completely blank for example if i try to print 9 label (= 3 row) the printer do 2 feed but nothing appear in the label i have tried to print the printer setting with this label format inside by the instruction in the manual and the info are correctly printed (for me is not a problem of paper or ribbon) i have tried to re-install the driver for Zebra Designer after downloaded it by zebra Home site the file ZD1510Certified.exe and setting the driver ''ZDesigner TLP 2844-Z'' nothing changed. what is the problem?? and the solution?? Thank you in advance for your help and assistance.
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have...
(More)
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have tried to take barcode labels.From application, for each and every label i need to generate the label in PDF and the i need to take print. I need to take print directly from the application. Kindly assistance me. Regards, Ramesh ramesh.perumal@csscorp.com
