It should work, simply plug your PSC to your PC/Laptop and go to devices and printers, you'll see it there and then you'll see "Needs Troubleshooting. Click on your device with the right button of your mouse, and you'll see at the bottom of the drop down list "Troubleshooting" run it and follow instructions, after that should be working.
You can download the complete software installer from HP here. This is the Windows XP version; if you're not using XP, start here and pick your operating system from the drop-down list. The manual and user's guides are here. You really don't need the CD since you can get all the stuff that came on it from the HP site.
you need to reload drivers, get them from HP online free
search hp downloads go to HP-CANADA [ support &drivers
enter model psc2410 operating system windows xp and download free
This depends on why it is reading offline. First check if the printer is on and if any error lights are on. A common issue is the printer was out of paper and after refilling the tray, the OK button was not pushed. Next check the cable, reseat both sides. Try a new cable, under 9 feet long. If you use a print server or USB hub, try a direct connection.
Make sure the USB ports work by trying a known good device. Check the device manager in case the USB ports need a driver update or were disabled for security (In Windows: Start > Control Panel > Hardware > Device Manager (exact placement may vary)). Check that the USB ports aren't sleeping in the Advanced Settings of the Screen Saver.
Try turning everything off, wait a couple of seconds and then turn it back on. Also try disabling McAffee to test. When you go to printers and faxes on the PC, what is the status of your printer?
apply any greese material like vaseline on the steel rod on which the cartridge carriage moves.if that rod is become rusty the carriage sometimes cannot move freely on it and this happens,
u have to check the ink catridges(black and colour) in the printer whether the ink is full ,bcos if the ink is low this problem arise check if the printing page is un single colour if it is then ink is a problem
www.hp.com has the executables for both driver only and full features. If you're saying you dont have a high speed connection, I dont have a solution other than hardware upgrade.
