Panasonic DMR-ES30VS DVD Recorder / VCR Combo
Problem for Panasonic DMR-ES30VS DVD Recorder / VCR Combo
SONY DVD PLAYER DVP-SR200P BUT IT ONLY SHOW IN BLACK AND WHITE ?
By royalty_quee on Sep 13, 2009
Solution #1
posted on Oct 26, 2009
Not Rated)
inspirachion
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem, and it had to be returned. The Control Menu Display was missing items related to color, so it appears the player was not configured correctly at the factory. Plus, it has no optical outlet so you're stuck with crappy sound. I am staying well away from this model and advise other people to do the same.
Was this helpful?
Yes
No
Solution #2
posted on Sep 14, 2009
Not Rated)
greginsocal
Rank: Master
Rating: 0%, 0 votes
You have posted this in the Panasonic DMR-ES30VS section.
Please note which product section you are in before posting your question.
For the Sony DVP-SR200P there could be multiple reasons for it only showing in B&W.
Was this a recent problem, is this a new hook-up, has it always been this way?
  1. In the setup menu there is a setting for Custom Picture Mode.
    Could someone have turned the color down?
    You can go to the setup menu and "Reset" the player to the factory settings.
  2. How is this connected to your TV?
    Check all cables to make sure they are plugged in, test each one by unplugging it, and then plug it back in fully.
    If you are using a composite cable (1 cable yellow plug), be sure you have plugged it in from yellow to yellow.
    If you are using the component (3 cables red-green-blue plugs) hook-up, be sure you are using cables only designed for component hook-up, and have plugged them in correctly, red to red, green to green, blue to blue (Be sure you've plugged the red cable into the red video not red audio).
    Are the cables in good condition?
    No breaks, loose connectors, they weren't smashed under a piece of furniture?
    Have you tried a different set of cables?
  3. Test the DVD player on another TV.
    Does the same thing happen?
    Did you "Reset" the DVD player?
    Maybe the DVD player is bad?
  4. Find another DVD player and test it with your TV.
    Does it work OK, or is it black and white too?
    Maybe the connectors on the TV are bad?
    Is there a custom setting on the TV for that connection?
    On some TVs you can adjust the settings for each input (INPUT 1, INPUT 2, ....) maybe the color setting is turned down?
There are may possibilities, but these are some of the basic things to check.
Best wishes,
-Greg-
Was this helpful?
Yes
No
Popular Solutions for Panasonic DMR-ES30VS DVD
Questions and Unsolved Problems for Panasonic DMR-ES30VS DVD
Do you recommend Panasonic DMR-ES30VS DVD Recorder / VCR Combo?
Answer
Answer
when playing a dvd on my player to view on tv a sign bitrate is permanently on screen how can I get... (More)
Answer
my dvd recorder is freezing and sometimes not reading discs
Answer
Panasonic DMR-ES30V VCR/DVD combo. Can anyone provide a copy of the schematic diagram or service... (More)
Answer
l have a panasonic dvd recorder DMR-ES30VEB which keeps blowing fuses.Works for about 20 secs then... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic DMR-ES30VS DVD...:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
