If it's not that, you can check this:
http://www.ehow.com/how_5870417_modify-dyson-prefilter-suction.html
Most likely blockage in the foot. Check for hair etc wrapped on the brush and clogging suction port. Twist 3 plastic 'screws' ati clockwise 1/2 a turn and remove base to access the brushes.
SOURCE: Dyson DC07 loss of suction
Hi.
Check brush roller is spinning when vacuuming.
Check short clear hose under machine for rips & blockages.
http://dysonmanuals.llc.nu/
Chris..
SOURCE: dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
SOURCE: Loss of suction
There should be a sponge like filter in the area of the canister and no this is NOT the HEPA filter. When you find this other filter you will want to bang it off outside and then put it back in and you should be all set.
Testimonial: "Worked like a charm"
SOURCE: Dyson suction has lost power
You might try this for free:
