Question about Seagate (ST9100801U2-RK) (9W3638556) 100 GB Hard Drive
  • 205 Answers
SOURCE: Downloading from Itunes
Your Itunes library may consist of MP4 (Itunes format) files, WAV files, and MP3 files. If you're attempting to transfer MP4 files to your MP3 player, then no it will not work. You'll need to convert them to MP3 format first.
Here's the really bad news...the only way to convert an ITunes MP4 song is to first burn it to a CD. Then you need software to pull the song from the burned CD back into your computer in whatever format you choose. Nero is an example of software that will accomplish this. I use rewritable CD's to do this so you don't waste a bunch of disks.
This was by design from your friends at Apple.
Hope this helps.
Posted on Dec 19, 2007
  • 40 Answers
SOURCE: IPOD music list gray in ITUNES
This seems to be a common problem among certain users. Here is an explanation of why it occurs as well as a solution:
The songs displayed on the iPod "playlist" is merely a list, not a shortcut to the file. Basically, it is to show you what is on your iPod, and you cannot move the songs because you aren't manually syncing your iPod.
The solution to this is simple, as much of a pain as it might be: on the iPod screen, where the iPod's name is displayed as well as firmware version etc. there should be a box in the lower right hand corner that says "sync automatically". Once unchecked, you will be able to play and remove songs one by one, instead of iTunes combining them into a text list.
Hope this helps.
Posted on Mar 11, 2008
  • 28 Answers
SOURCE: i downgraded itunes from 8.0
You can fix this by updateing. Apple puts blocks in place to cause the older versions to stop working. They do this because people learn how to unlock the music they buy on itunes so Apple has to create new locks. To avoid this, never update. They claim to be fixing bugs but they are really making it difficult to remove the locks. They are also updating itunes for the itouch and iphone.
If this didn't help, you can go into chat on Apples website and they will tell you more about the error code being thrown. Good Luck,
Posted on Jan 02, 2009
  • 2794 Answers
SOURCE: itunes won't save my library
Its really tough when you have multiple IPods going on one computer. The best bet is to take a library and add every song into the computer available. Then create a seperate playlist for your daughters songs and one for yours. Then use the playlists to add to the Ipods in the future. That is really the concept to the library in the first place.
Posted on Jan 18, 2009
  • 553 Answers
SOURCE: I have a 1 terra bit external hard drive . I
Your installed music library in your external hard drive might not be supported by your media center on your new laptop, try to convert the files where the software are supported by your media player. try convert Master software, you can download it free then convert your files
Posted on Nov 01, 2009
  • 71 Answers
SOURCE: itune library cannot be read because it was
The easiest solution is to close iTunes, delete or drag out iTunes Library.itl.
Start iTunes, then add your music folder.
Posted on Apr 29, 2010
0 characters
1 Points
How do I backup itunes file on external harddrive
It's a good idea to regularly back up all important files on your computer to an external source to prevent data loss. Your iTunes music, videos and other digital downloads are stored in separate files within the iTunes folder. However, if you consolidate them into a single folder, it's easier to back them up to an external hard drive.
Launch iTunes. Go to the program's Preferences menu. Click the "Advanced" tab. Check the box next to "Copy files to iTunes Media folder when adding to library" and click "OK." Click "File." Select "Library" and then "Organize Library." Check the box next to "Consolidate Files" and click "OK." Close iTunes. Connect your external hard drive to your computer. Find the iTunes media folder on your computer's hard drive. Drag the folder to the icon for your external drive to copy your iTunes media.
Back up your iTunes library by copying to an external hard drive
Mar 19, 2013 | Hard Drives
How do I transfer my music library to a new computer using the simpletech 1tb simpledrive?
itunes requires that you authenticate a computer with your log in account simply log in with old computer, save the itunes library to ext drive
then de authenticate the old computer
log in with new computer and authenticate it
then bring the itunes files on to new machine
takes a while but it works
Jun 14, 2012 | SimpleTech 1TB HITACHI SIMPLEDRIVE IIUSB...
My seagate hard drive was said to have bad sector and have this terrible buzzing sound, is there any way i can recover my files on my hard drive?
You may be able to if you remove the drive and put it in to a portable drive enclosure. Then plug it in to another pc's usb port.
Feb 08, 2012 | Seagate Hard Drives
I have more hard drive space available then I could possibly use. Is there anything useful that I could do with it?
Good for you that you have an available space in your computer. Just leave it like that for future use. Don't just download or install any software there. You will need that space someday.
The advantages of having a more hard drive space:
1. Speed.
2. You can save more files, music, pictures, etc.
I suggest not to do anything yet which you think is not important. As time passes by, there are files that will be added there as you use your computer.
Mar 27, 2011 | Seagate HDST3500418AS Barracuda 720012...
I don't know how to save all my i-mac music into the Seagte hard drive? I've followed the instruction few times and download the software, but I just don't don't know how to save my i-tunes music into the...
open up Itunes in the top left hand corner select file from the drop down list select library then you will have options toback up to disc organise library export library import playlist and export playlist
hope this helps
Mar 22, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have 60 GB sea gate sata hard drive i need to recover the data from hard drive but it is not detecting so please help me how can i detect the drive
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy all your files to a brand-new disk-drive.
Nov 02, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
I have a 1 terra bit external hard drive . I edited music from a pc to my external hard drive using cd's & lps. I've been having problems with putting my music library in my new laptop computer. One...
Nov 01, 2009 | Seagate Free Agent Go Small 12 GB USB...
Song files donn't STAY in iTunes
The songs are located on your Simpletech drive. You have to move them to your music folder and then specify where the library is in iTunes. If you do have music in your music folder, then on XP, after you have iTunes open, go to Edit -> Preferences. Click on Advanced, and then change the library location.
Apr 16, 2009 | SimpleTech SimpleDrive 160 GB External USB...
Tansfer i tunes to sea gate
Hi towardtheone
What you need to do is change your iTunes Library "path".
There's a great little How To article HERE that may just do the trick for you.
Apr 03, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do i free up space on my start up disk?
your problem is the space is it?i think on top of moving your itune library u should move all other less important files to any external storage and see whether this will solve the problem.
Sep 05, 2006 | Smartdisk - Peripherals - HARD DRIVE,...
Seagate (ST9100801U2-RK) (9W3638556) 100 GB Hard Drive Logo
93 people viewed this question
Top Seagate Hard Drives Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a Seagate Hard Drive Expert? Answer questions, earn points and help others
