Question about Onkyo TX-SR605 Receiver
No video throught HDMI output
So I recently set up my Onkyo TX-SR605 reveiver and have ran into a few issues that I can not seem to figure out. I have an HDMI output from my receiver into my TV. I have my monitor output as "yes" to HDMI. For my HDMI input, I have DVD as "_ _ _", as I am using component cables from my DVD player into my receiver. I have the Component input for DVD set as "In 1". The video seems to upconvert fine from compnent to HDMI into my TV. When I attempted to do the same thing with other component sources, such as my Xbox 360, I can get the sound to come in fine, but the picture does not come in. I know it is not my receivers component input, as I have tried my DVD player with the other component inputs into the recevier and the video feeds through fine out to my TV with the HDMI cable. So I am not sure why the upconversion with component cables works with my DVD player and not my Xbox 360.
Another issue I had was with the HDMI cable input into my receiver. I set my HDMI input setting for my cable box as "HDMI In 1" and the sound from my Cable box comes into my receiver, but no video is outputted into my TV through th HDMI cable. I don't understand what's going on. Please help, as I am getting frustrated with this whole thing.
  • 6 more comments
  • Onkya Newbie Dec 11, 2007
    I have my monitor out as HDMI. I see the menu, I just can't get any video to feed through except for my DVD player.
  • Anonymous Dec 17, 2007
    not much help to you but i ended up using my s video connection instead of component to get picture from my dvd player. sounds like a lot of people are having this problem.
  • try8this Jan 23, 2008
    I have similar problem. I got a brand new Onkyo TX SR605. I have a Panasonic - TH-50PZ700U 50-IN 1080p Plasma HDTV.
    I have input from directv receiver using composite cables. I want to upconvert this to HDMI. I also did HDMI monitor : Yes and set the input/output assign to ---.
    I can hear audio but can't see video. I didn't change any setting on TV. I noted that, there is HDMI monitor on on my TV as well.
    Please help.
  • Sarahmomx3 Apr 05, 2008
    I have sound output through the DVD player and the cable box but absolutely no picture. I don't know how may ways to plug in an HDMI cable (which are brand new BTW).
    And I still have no idea how to make my Tivo work with this receiver...
  • kemosaby May 05, 2008
    My satellite receiver HDMI out goes to the TXSR605 HDMI 1 Input. I choose the proper input with the remote but receive no video or audio. Nothing at all. But when I take the same HDMI cable straight from the satellite output to the HD projector HDMI in, the video works beautifully. Also, with that HDMI configuration (not even going through the receiver), if I use component cables from the satellite L/R audio outs to the Onkyo L/R inputs, the audio is heard beautifuuly. Bottom line, when using the HDMI connections, neither video nor audio passes through the receiver. Any clues?
  • SpaceHopper Oct 23, 2008
    I also have a SR605 AV amplifier and I am trying to connect my Sky HD HDMI output to the TV via the amplifier. I get sound but no image. I can see the HDMI monitor when selected but still no video image! This is very annoying as I wanted to use the encoded digital surround sound in the Sky HD signal which I cannot seem to do at the moment. any solutions?
  • joeFixYa56 Feb 01, 2009
    You should be an expert, not an "Apprentice", this worked for me (first I had to unplug the unit for a few minutes). I looked all over and this was the best answer!!!! Thanks botham1
  • Anonymous Mar 16, 2014
    my receiver has worked well for a long time. Now however when I use a dvd I get no sound except thru the tv. But if I use my cd player I get surround sound. I swapped the dvd player and the hdmi cable- no change. The dvd is on an hdmi input port and the cdplayer is on a cable input. the other hdmi ports devices don't get any surround sound either. Seems like a set up problem on the dvd port but I don't see any problems...
Press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Posted on Dec 11, 2007
You should be an expert, not an "Apprentice", this worked for me (first I had to unplug the unit for a few minutes). Thanks botham1
I looked all over, and this was the best answer!!
Posted on Feb 01, 2009
TX SR605 will only input composite sources at 720, if your X-box is set to 1080 then the signal is blocked through the HDMI output. Change x-box resolution or go straight to TV via composite.
Posted on Feb 07, 2008
I have solved this problem. I've managed to get my Sky HD and Playstation 3 to play through the amp. You setup the HDMI inputs in the Input/Output assign. Once you have donew that go to the 'Source Setup' menu, select 'A/V Sync' then press enter as requested, you should then see an image. This worked with me after fiddling around with it for a while but it does work.
  • 14 Answers
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Posted on Dec 13, 2007
SOURCE: onkyo upconversion problem
This may be due to a limitation of the Faroudja DCDi chip used in the Onkyo receivers. See the Onkyo FAQ: http://www.us.onkyo.com/faqs_detail.cfm?detail=1&id=268
Posted on Dec 31, 2007
  • 6 Answers
SOURCE: cant find universal remote code for the onkyo tx-sr605
Your onkyo receiver and remote controller only decodes 4 digit codes so what you have to do is to call the manufacturer of the remote controller it self and ask for the hexa decimal codes for their remote. They should provide it to you coz they're the ones responsible on doing that.
Posted on Nov 29, 2008
  • 4234 Answers
SOURCE: hdmi out [of amp damaged needs replacing onkyo tx sr605
You will need to contact Onkyo directly and request the board from the parts department. I was not able to locate a part number for this as we are usually requested to perform component level repairs for these units.
Dan
Posted on Nov 04, 2009
SOURCE: won't turn on.standby light on,fuse under cover is
Mine will turn on for a few seconds then whill shut off again but the standby light would stay on
Posted on Feb 16, 2010
Unable to connect a blu ray dvd player to onkyo tx-sr605 via hdmi
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Select INPUT OUTPUT ASSIGN
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
HDMI INPUT
DVD - IN1
CBL/SAT - IN2
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Apr 13, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Sound won't play through Onkyo TX-SR605 when using HDMI
The chances are that you have selected an incorrect sound setting or not switched it on, for the HDMI you are using. With Onkyo receivers each connection will have it own settings for video and sound. You just need to look in the manual as to how to select the settings.
May 08, 2017 | Onkyo TX-SR605 Receiver
I have an Onkyo TX-SR605 AV receiver that just stopped outputing video to my Panasonic projector. I have connected other devices directly to the projector and video is fine, so the problem is not the...
Goof information. Have you eliminated or proven the Onkyo as a cause by going direct to the projector? Try another Input and/or Output. It's best to know which component is broken and if it's limited to a specific subset of its function.
Settings are also indicated. Run through the video setup again. If it just stopped, what preceded it?
Nov 27, 2009 | Onkyo TX-SR605 Receiver
DVD signal received in wrong aspect
PRESS SETUP GO TO MISCELLANEOUS PRESS ENTER THEN DOWN TO OSD SETUP PRESS ENTER AGAIN AND DOWN TO MONITOR AND CHANGE TO 16.9.
HOPE THIS HELPS.
CABLE GUY.
Feb 21, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 video problems
Bypass most reviews say video area is still alittle shaky
Feb 08, 2008 | Onkyo TX-SR605 Receiver
Onkyo 605 HDMI Sound
Change the setup in the Hardware control/HDMI/ HDMI Audio...
Jan 17, 2008 | Onkyo TX-SR605 Receiver
Video on game and dvd seem to work
DO you have hdmi monitor turned on?
Jan 05, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver HDMI Issue
How good are the hdmi cables that you are using???
Nov 26, 2007 | Onkyo TX-SR605 Receiver
Brand new Onkyo Tx-sr605 won't leave stand by
If the unit will not leave standby I would remove all power, disconnect *all* connections at the back, reconnect to a power source and try powering on. This will eliminate any connection causing the Onkyo to stay in standby due to a short. If it still will not enter power-on mode, you may want to look at the power source (is it properly grounded?), but beyond that the unit probably needs to go back.
Nov 03, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver Logo
7,325 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
