Question about RCA F27242GY 27" TV
My tv dose not turn on
My tv not turn on
  • 2 more comments
  • adarwireless Dec 11, 2007
    tv pluged into power but tv do not turn on
  • Vineeta Feb 01, 2008
    I have Mitsubishi Model # VS50607 Big Screen TV and it does not turn on.
    What can you do to help me solve this problem? Do I need a new bulb, lamp, etc? It works once a month
  • tommy girl Mar 30, 2008
    I have a VCR and DVD combo television that will not turn on. I have no images or light It just "clicks" On then "clicks" OFF. Is it time to but a new set?
  • bsherrill82 Apr 20, 2008
    our tv is not coming on, we dont see not picture or snow. we are using a computer cord for it cause we just bought it and it didnt have a power cord for it. its a rca big screen home theatre tv please help!!!
  • RCA Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on Jan 05, 2012
WHEN I TURN ON BY BIG SCREEN TV IT WANT COME ON
Posted on Dec 12, 2007
    President:
  • 4,402 Answers
Do you get any blinking power light?
Check these out to see if they help.
CTC176 DEAD
Open C4127 10 mfd 63v in regulator circuit.
CTC176
DEAD SET
CHECK/REPLACE R4104 (1.5m @ 1/2w)
CTC176
DEAD SET WITH NO SOUND OR PICTURE BUT HAS HIGH VOLTAGE
CHECK/REPLACE CR4704,R4702 AND R4517
CTC176
DEAD SET OR INTERMITTENT SHUTDOWN
CHECK/REPLACE T4101 OR CHECK CONNECTIONS ON PIN 8
Posted on Dec 11, 2007
    Problem Solver:
  • 13 Answers
Try unplugging it from the wall, wait 1 minute, then replug.
I presume you have tried both the remote and the button on the front of the set.
My tv dose not turn on , its show power light red and when I plug in its sound like timer and , then screen turn grey, I can not change any mode or volume , and can not turn it off , I have to plug it out,
hello sir,
please sir solve my this problem.
my tv dose not turn on , its show power light red and when I plug in its sound like timer and , then screen turn grey, I can not change any mode or volume , and can not turn it off , I have to plug it out,
Dec 07, 2009 | Panasonic Viera TH-42PX80U Plasma TV
My samsong tv ps-42p2sb stoped working
Since your tv is in warranty call 1-800-Samsung. They will set up a service call to repair your tv.
Jul 03, 2009 | Samsung PS42P2S 42 in. Plasma Television
THE TV SHUTS OFF IN THE MIDDLE OF A TV PROGRAM,
It seems that you have a ballast issue, I've handled various ballast issues and when I purchase them i go with a company from San Diego, they got great prices and excellent service... they also give free troubleshooting, so they're good check em out if you like discount-merchant.com
Jun 30, 2009 | Samsung Televison & Video
My picture dose not work but my sound dose how do i fix this problem
go for the HORIZONTAL OUTPUT TRANS or THE VERTICAL IC , , check those 2 sections , good luck AJ
May 15, 2009 | Panasonic CT-32E13 32" TV
Television Went Dead
When you first turn it on dose the LED blink? if it dose then maybe the inverter board went bad if the LED don't blink then maybe power supply
Jul 10, 2008 | TruTech PLV16320 Television
i have a ct-36hl43 it was ac fuse gma 6.3 amp its on the panasonic web site under parts cost a dollar randy vincent ragingbass@comcast.net
Dec 29, 2007 | Panasonic CT-36HL43 36" TV
Freezes up or just dose not show on tv
you xbox is probably dead smack it up a bit. nah jokes you need pro help
Dec 25, 2007 | Microsoft Xbox 360 Console
I need more information on the TV. Make, model, is it a plasma or not, ect.
Dec 23, 2007 | Sony KV-32XBR85 TV
RCA F27242GY 27" TV Logo
126 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
