Setting up my freeview box- NO CHANNELS FOUND
I have just moved into a new shared house which has a old cable and wireless box with an areial coming from the wall into the black box. I want to set up my freeview but its not picking up any channels. If i bypass the black box and put the arial from the wall into my TV i can get a perfect picture but when i set up my preview it can't pick up channels...i am at my wits end with it PLEASE HELP
  • 372 Answers
Hi.
The cable & wireless system is not capable of picking up the digital freeview frequencies.
Idealy you need to put a new aerial on the roof,
If this is not possible try an indoor aerial that you to plug in to the mains electrical supply.
http://dysonmanuals.inc.io/
Chris..
Posted on Dec 12, 2007
I have a sony EX4|40 with built in Freeview. However, the port on the tv is a UHF (?) port (Im not technically minded, my port names may be wrong so I hope you know what I mean), The cable which runs from...
xtreamz_69,
It sounds like you connected the coax cable to your TV. What channel is the TV set on when you have the Freeview connected? Because you are using a coax cable, the TV should be set to either channel 3 or 4 (normally channel 3). Check to make sure your TV is on one of those channels. Also verify your receiver is on. Your TV has the several other type ports (HDMI, component, composite) as alternatives to pick up your picture. If you have any other questions, please post to this site.
Ray Calo
DISH Network
Jan 19, 2011 | DISH Network IR Remote Control
Problems on the freeview 21inch Tv Teknica from Tesco was working when we bought it 2 years ago cannot get all the channels and poor reception re installed channels many many times but does not maintain...
you may want to try changing the coaxial aerial cable that feeds the tv, these can go faulty. also if you are running a series of tvs off one aerial, you should be using an aerial booster, other wise you will get a signal drop (as displayed on your tv).
If these small things don't cure it, the set requires replaceing as the tuning card is knackered
Jan 16, 2011 | Audio Players & Recorders
Hi I have two freeview boxes running from one aerial which split at a boooster box, one tv works fine, it the farthest away from the booster box, but the other has some channels freezing up and stuttering,...
The problem you describe is called "Digital Cliff Edge" and it's caused by signal loss. I wont go into the specifics of that at the moment as it's not going to help solve your problem. I you want more information about DCE, try an internet search.
As you are using the same aerial and booster/splitter for both TVs, you are correct in ruling these out as the cause of the problem. The fault is probably in the co-ax cables or connections but you might have a faulty freeview box. Please run through the following checks to establish the source of the fault.
1. Swap your Freeview Boxes - you shouldn't need to re-scan/tune as they are running off the same aerial..
If the Freeview box from the TV that is working correctly freezes and stutters on the other TV, the fault is probably in the cables or cable connections. Next, try the "faulty" Freeview box on the TV that is working correctly. If you get stuttering sound and freezing/pixellation you probably have a faulty Freeview box. DO NOT SWAP ANY CABLES FOR THIS TEST.
If the problem is the same after swapping the freeview boxes:
2. Swap any non-fixed cables, e.g the co-axial "fly-leads" and scart cables - one at a time. See if the fault "moves" with the swapped cables. "Fly leads" are the short co-ax cables that link the Freeview box to the TV or the TV to a wall mounted aerial socket. If the fault "moves" with the swapped cable, you have identified the source of the fault and should either repair or replace this cable.
Try these tests first and post back with the results. If you haven't identified the source of the fault, I will try to assist you further.
Regards,
BElectric
Nov 21, 2010 | Televison & Video
I bought a Toshiba 32 Inch HD Ready Digital LCD TV - 32BV500B yesterday from Argos, Leyland. I tried to set it up and it searched for programmes but did not return and any programmes. It had a blue...
Are you using the freeview tuner, I only ask as it looks like your having a similar problem that I had a few months back. I moved into a new house and plugged in the tv. Using the freeview tuner I wasnt able to get any channels. It turned out although the aerial picked up regular analogue tv it wasnt the correct aerial for freeview.
Aug 17, 2010 | Toshiba Televison & Video
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Connection problems with Philips DTR220
There is such a thing as a HD areial, but in this case it sounds like you need to point the antenna in the right direction. If your freeview is digital then there is a diredtion the areial needs to piont, and there is a front and a back to it. You need to find where the signal source is located and point the areial in that direction.
Mar 30, 2008 | Televison & Video
Freeview box and dvd is not working
Have you checked the fuse in the plug for the dvd player?
Feb 18, 2008 | Televison & Video
Using an old SKY digibox for Freeview ?
you have a smartcard for that box ?, cause without that card, you won't see any of the channels at all.
Nov 11, 2007 | Televison & Video
Televison & Video Logo
908 people viewed this question
Top Televison & Video Experts
