Question about Canon Ir 3300 Black & White Copier
Sir i have ir 3300 machin contnyu paper jam 212 problam wats probal
SOURCE:
ctf1800
  • 4402 Answers
SOURCE: ir 3300 paper jam
the heater section is the fuser you should be able to pull the tray out and then lift the door of the fuser
Posted on Sep 03, 2008
  • 199 Answers
SOURCE: Canon IR 3300 switchs on it displays the Erro E000602-0003
replace hard disk drive
Posted on Feb 15, 2009
  • 7 Answers
SOURCE: how to solove thiis problam ir 3300 E000602-0003
Just entered in service mode by press add. functon button then 2&8 together and add. functon button, in service mode entered in Copier then function then clear and touch ok tab in touch screen. restart ur machine error code should be cleared.
or run harddisk scanning mode by holding 1 & 9 buttons then switch ON machine. it will take one & half hour.
if still there is a problem then you need to change your machines HDD.
Posted on Jul 17, 2009
canontech
  • 1219 Answers
SOURCE: my ir 3300, always get a jam paper, how i cant fix
Where does jam occures?
In fixing section, in duplex, in paper tray,...
Please be specific!
If you want service manual, or further help, you can contact me on [email protected]
Posted on Jul 10, 2010
SOURCE: cannon ir 3300 eror code
JAMD PAPER BUT WE HAVE NO SHOW THE PAPER
Posted on Sep 01, 2010
I have cannon ir 3300 image runner it shows paper jammed in right side but there is no paper jammed in any side of the machine
Manoj, Try using compressed air to blow dust and debris out of printer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix paper jam Canon iR3300 printer
Home Canon Italia
https://www.usa.canon.com/internet/portal/us/home/support/details/copiers-mfps-fax-machines/support-multifunction/imagerunner-3300
Aug 20, 2016 | Canon Ir 3300 Black & White Copier
Canon ir 3300 have a problem for paper jam in fixing film so how to solve the problem
there is an error in the rotation of the fixing film.
check the fixing film sensor and make sure that all the wiring and the connectors are connected securely.
if it persists, consider replacing the fuser fixing film
thanks
Aug 17, 2014 | Canon IR 3300 Digital Copier
Sir in my canon ir 3300 machine when paper pick form caseette no.1 the paper is not pick uped and sound like kad........means one of the gear is not smoothly runing and paper is jammed . so plz sir solve...
the problem is in paper pick-up assembly, in paper cassete lifting clamp. The lifting clamp is damadged and can't turn the gear wich lift's the paper plate in drawer.You need to remove whole pick up assy and replace the clamp. The klank-klank sound is charachteristic for these problem.
Firstly you need the parts cataloq and service manual.
[email protected]
Best regards!
Oct 15, 2010 | Office Equipment & Supplies
ERROR CODE e000602-0003 HOW TO CLEAR THE ERRROR APPEARING ON THE SCREEN OF CANON IR 6000
This is HDD related problem, try : turn off copier pres 1 and 9 (hold it ) then turn on the copier. That initalizes the hdd defragmentation. if does not help, you need to change the hdd and "fill" it with system software.
Apr 23, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Paper has jammed showing error code 0000064 and inform to restart
canon3000 err code 64 restrt machine 10 to20 copy after code please help me
Dec 16, 2008 | Canon MF8180C Color Laser MFC Printer
Ir 3300 paper jam
Sep 03, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon Ir 3300 Black & White Copier Logo
Clive
Clive
old marine
old marine
Ekse
