Question about Toshiba TZ50V51 50" Rear Projection Television
Problem with convergence that remote can't solve
  • Anonymous Jun 09, 2008
    the picture goals out and the red light continues to blink. Once unplugged and replugged the picture come back clear. This will happen over a time and then the TV would work fine.
  • dmh8181 Dec 01, 2008
    The convergence adjustments from the remote do not solve the problem completely. Still a lot of distortion near the sides, bottom and top of the screen.
  • 4,402 Answers
Convergence amp ic are bad stk329-110 and possible resisters.
Posted on Dec 11, 2007
Convergence problems with the Toshiba TE50T11. Have tried to fix by remote and the colors will not align as they should. Left side of screen has blurriness, almost a 3d effect with alot of greenish tones....
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
Dec 02, 2010 | Toshiba TZ50V51 50" Rear Projection...
Red and blue colors wont converge and picture is warped
Replace the convergence ICs you have 2 of them they will have PN on them STK-392-110s? Mats Electronics has them 1-800-628-1118
Sep 15, 2010 | Toshiba TZ50V51 50" Rear Projection...
The lower left corner of the picture has a red out of line convergence. It will not adjust. what can I do?
The tv have convergence problems is dead.The tv convergence board require 2 STK convergence ICS and some or all it resistors changing.To solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 14, 2010 | Toshiba TZ50V51 50" Rear Projection...
Tv stopped working and red light started to blink
this problem can be solve by changing the 2 IC of convergence. part # STK 392-110. It would take 30 to 60 minutes to open change and reclose.
Apr 23, 2010 | Toshiba TZ50V51 50" Rear Projection...
Shadow on my tv
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 18, 2009 | Toshiba TZ50V51 50" Rear Projection...
My tz50v51 shows a double picture
replace the 2 convergence ic stk392-110 they are located on the same boad with the divider
the transfromer that supplies the pic tubes. they cost about $20. each have any other questions my ermail is
Feb 23, 2009 | Toshiba TZ50V51 50" Rear Projection...
Red double picture with green and blue
convergence problem there are 2 integrated circuits inside the set needs to be replaced
Aug 25, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba Cimema Series 55''
most probably the convergence is going bad, enter the menu and realign the converg. match the red to green and the blue to green
Aug 17, 2008 | Toshiba TZ50V51 50" Rear Projection...
Convergence problem
You need to replace both convergence ICs number STK392-110 youcan get replacements at the following link and they provide free installation instructions with pictures so you can do the job yourself . heres the link.
May 04, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba TZ50V51 50" Rear Projection Television Logo
262 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
