Second DirecTv box unable to locate a signal
Hi
I have a Hughes model SD - DVR 80 hooked up to an 18 Inch x 20 Inch Triple LNB DIRECTV Multi-Satellite Dish Antenna. I have four feeds coming into the house - two of which are connected to the above DVR. I also have an older Hughes box - model HIRD - D2 that I want to use in another room. I just hooked it up - the phone connection is good; the card is still good; but I'm getting no signal from the dish. My DVR is pulling in a strong 95 to 100. I have tried connecting using all four cables with the same result.
My System Test shows the following:
Version 4031.0,0,0
Signal - unlocked
Tuning - trying
Phone - OK
Access Card - OK
Front panel - OK
When I test the strength of signal, I pull all zeroes. Any help would be appreciated.
  • Peterm02081 Dec 11, 2007
    Is the simple answer - it's not multi-sat compatible?
  • Peterm02081 Jan 15, 2008
    Thank you - I'll give it a try!
    Problem Solver:
  • 26 Answers
It is multi sat multi sat compatable!My opinion is buy a powerd multi switch you can getem at radio shack or from a sat dealer that will clear p your prolem i belive also check all your rg6 coax ends u may have a a bad splice or a fraid shiel wich will make your reciever do the same thing but hope you can fix it
Goodluck
Please rate
Posted on Jan 15, 2008
Need helping hooking up to my existing directv box
About 409,000 results (0.52 seconds) Search Results
    DIRECTV Genie® WiFi Setup & Connection ' DIRECTV ...
    https://support.directv.com/.../directv-genie%26reg%3B-wifi-set...
    DirecTVWatch this video to learn how to connect your Genie® HD DVR model HR44 to the Internet. Follow the simple ... No, my router does NOT have WPS or I want to configuremy router manually. Image .... Order DIRECTV Existing... Still need help?
    Do I need additional equipment to connect more than one TV
    https://support.directv.com/app/answers/detail/a_id/3945
    DirecTVYou need one Genie Mini or Wireless Genie Mini for each additional TV. ... So in a Genie Whole-Home HD DVR setup, one of your TVs is directly ... which allowsDIRECTV Ready TVs to be connected to the Genie HD DVR as additional TVs in your setup without a Genie Mini. ... Order DIRECTV Existing. ... Still need help?
    How to Connect DIRECTV Receiver to TV ' DIRECTV Support
    https://support.directv.com/.../how-to-connect-directv-receiver-t...
    DirecTVHow do I connect my DIRECTV receiver or Genie Mini to my TV? ... This will help you determine what cable to use. .... To download and print them, you'll need.
    My equipment was shipped to me. How do I install it ...
    https://support.directv.com/app/answers/detail/a_id/4267
    DirecTV
Feb 08, 2016 | Televison & Video
II just want to ask a question about a TIVO DVR.
You can buy a used DirecTV with Tivo. You probably had a Hughes SD-DVR40 or SD-DVR80 before. The used model needs to be transferable to your account (which means it can't be leased, it has to have no outstanding charges on the previous account, etc). And you have to buy a new DirecTV card.
If you are in the San Francisco Bay Area or in San Jose, write to tivorepair@gmail.com and they should be able to help you out.
May 17, 2010 | Directv HD DVR TiVo DTV Receiver /...
Hughes sd-dvr-80 rebooting randomly now stays on powering up when
This is common with drive problems.
Could also be a power supply getting hot.
Apr 12, 2010 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Can hughes sd-dvr 80 be used as stand-alone dvr?
not without a subscription to Directv. after it enters the box it is basicly a Directv signal, it has to show up on the program guide.
Mar 10, 2009 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Pixelating & freezing of picture
Hi, Pixelating and freezing are symptoms of loss of signal. You need to check all of your connections. Check for water in any connection. Check your satellite signal strength on each satellite and if low or they are all not there you could have a bad LNB but you need to check the LNBs and the multiswitch for poor or bad connections. Also check for any obstructions in the dish view to the sky or for anything that may not have been tightened down on the dish. Snow and ice builtup will cause this problem as well. Good Luck! Let me know what you find.
Feb 03, 2009 | Hughes Televison & Video
Hughes DirecTV TiVo SD-dvr80 quit working
the are some new features that tivo does not support. you still can watch your saved programs. Sadly the older tivos are equipped for the digital transitoins. I know Tivo and Directv are releasing a new receiver in a few months.
Jan 07, 2009 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Hughes SD-HBH Satellite Multiswitch Compatability
DiSEqC Tone burst multiswitch are not compatible with directv equip
Dec 31, 2008 | Hughes SDHBH DirecTV DTV Receiver
Searching for Satellite
The voltage is supplied by the power-supply through the RF/IF interface usually encased in a metal box on its own. Also without knowing the model number of your unit I cant help any further.
May 16, 2008 | Hughes SDHBH DirecTV DTV Receiver
Program Code
DIRECTV Model D-10 00001, 00002
Hughes Network Systems (most models) 00749
Hughes Network Systems models GAEB0, GAEB0A, GCEB0, GCEB0A,
HBH-SA, and HAH-SA 01749
GE models GRD33G2A and GRD33G3A, GRD122GW 00566
Hitachi model HDS210R 00819
Mitsubishi HD models SRHD400 and SRHD500 00749
Panasonic models TZ-DBS01 and TZ-DRD100 00247
Panasonic models TUIRD10 and TUIRD20 00701
Philips models DSX5150R,DSX525R/I, DSX5350R, DSX5353R,
DSX5353X, and DSX5375R 01076
Philips models DSX5500 and DSX5400 00099
Proscan models PRD8630A and PRD8650B 00566
RCA models DRD102RW, DRD203RW, DRD301RA, DRD302RA,
DRD303RA, DRD403RA, DRD703RA, DRD502RB, DRD 503RB,
DRD505RB, DRD515RB, DRD523RB, and DRD705RB 00566
RCA models DRD202RD, DRD221RD, DRD222RD, DRD223RD
DRD225RD, DRD420RE, DRD440RE, DRD460RE, DRD480RE,
DRD430RG, DRD431RG, DRD450RG, DRD451RG, DRD485RG,
DRD486RG, DRD430RGA, DRD450RGA, DRD485RGA, DRD435RH,
DRD455RH, and DRD486RH 00392
Samsung model SIR-S60W 01109
Samsung models SIR-S70, SIR-S75, SIR-S300W, and SIR-S310W 01108
Sony models (All models except TiVo and Ultimate TV) 01639
Toshiba model TSR101DSS 00790
Uniden model UDS100 00724
Setup Codes for DIRECTV HD Receivers
DIRECTV Model H-10 00001, 00002
Hitachi model 61HDX98B 00819
HNS models HIRD-E8, HTL-HD 01750
LG model LSS-3200A, HTL-HD 01750
Mitsubishi model SR-HD5 01749, 00749
Philips model DSHD800R 01749
Proscan model PSHD105 00392
RCA models DTC-100, DTC-210 00392
Samsung model SIR-TS160 01276
Samsung models SIR-TS360 01609
Sony models SAT-HD100, 200,300 01639
Toshiba models DST-3000, DST-3100, DW65X91 01749, 01285
Zenith models DTV1080, HD-SAT520 01856
Setup Codes for DIRECTV DVRs
HNS models SD-DVR80, SD-DV40, SD-DVR120,
HDVR2, GXCEBOT, GXCEBOTD 01442
Philips models DSR704, DSR708, DSR6000,
DSR600R, DRS700/17 01142, 01442
RCA models DWD490RE, DWD496RG 01392
RCA models DVR39, 40, 80, 120 01442
Sony model SAT-T60 00639
Sony model SAT-W60 01640
Samsung models SIR-S4040R, SIR-S4080R, SIR-S4120R 01442
10
PROGRAMMING
Jan 26, 2008 | Directv RC23 Remote Control
My reciver is on but the video
do a master rest on your unit, Then check your signal levels on all of your transpondeyour house rs it sounds like you have a bad lnb, fraid wire, or your reiever is hooked up to a spliter u cant hook up a dvr to a spliter check your your coax ends if no succes then call directv if you have the insurance plan and tellem its bad and youneed a replacement also do u shut your reciever down at night or when u leave house it also sounds like it needs to update
Goodluck
Please rate
Nov 22, 2007 | Directv Plus DVR DTV Receiver / 100-Hours...
Televison & Video Logo
367 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
