Question about T-Mobile Sidekick® 3 Cellular Phone
T-mobile phone Not Charging
When I connect the charger it shows me "NOT CHARGING". Plz reply ASAP. Its very urgent.
Thanks.
  • 1 more comment
  • Ahmadd Dec 11, 2007
    The charger is working fine because when I connect it, the phone recognizes that a charger is connected and immediately pops up the screen saying "NOT CHARGING". Previously when I connected the charger it said "CHARGING" but now when I connect it, it gives a beep sound and says "NOT CHARGING".
    I would really appreciate if you help me solve this problem. Its very urgent.
    Thanks.
  • duygu Dec 11, 2007
    i bought a used sidekick and when i bought it, it was working fine. the battery was finished so i bought a new charger. the light to the charger is lite up, indicating that the charger is working but my phone wont turn on. is there something wrong with the battery? please let me know
  • Anonymous Mar 14, 2009
    my charger is not charging my sidekick 3
    President:
  • 625 Answers
The charging port on a sidekick 3 is know to go bad. It can run about 100 bux to fix if it is out of warranty.
If it is warranty call T-mobile and get it fixed.
Another solution is to get an external charging cradle and spare battery. Make sure you get a cradle that has the spare battery charging slot. I think it is made by monaco.
You can find them on ebay. Total will run you about 40 dollars.
http://shop.sidekickskin.net/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Posted on Dec 15, 2007
Sorry GUys the charger pin inside the fone is broken. This is a common problem with the SK3s. Upgrade to The LX is charges VIA USB
Posted on Dec 14, 2007
    Scholar:
  • 152 Answers
To where are you connecting the charger?
how old is the charger? maybe the cable its broken in the inside... this usually happens at the ends of the cables or if there is a little bump somewhere..
try connecting them and play with them by moving them a little at the ends.... so there will be better a contact..
Posted on Dec 11, 2007
  • Asdrubal Perez Dec 11, 2007
    can you specify me the model so i can make some research?
    to where are you connecting the other end of the charger?
Charging problem
Hello My Dear::::::::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 12, 2013 | Cell Phones
My Bold 9700 shows external power and its not charging at all!!? plz helppp
First Option:
Second Option:
Sep 06, 2012 | RIM BlackBerry Bold 9700 Smartphone
My Nokia 1112 displays 'Test mode' only and doesn't switch on!
charge your mobile and while charging try to turn on.make sure the charger is connected properly. else u need to check on the charging pin in the mobile.
Aug 20, 2009 | Nokia 1112 Cellular Phone
Charging problem
1st thing you should check is the charging port. It is not SOLDERED to the board and is only connected by 2 springed prongs. If you are hand, open the phone real carefully and gently bend the contacts forward. Also take a pencil eraser and wipe the contact connections on the phone. Then put your phone back together and see if it works. Good luck
Mar 10, 2009 | Nokia 6300 Cellular Phone
Battery Wont Charge
either the battery is drained so its not getting charged. remove the battery from the cell and check out.or the charger is faulty so need to replace the charger.sometimes pressing the pin of charger in to the cell gets connected internally and the charging starts try it.other wise that two above things need to be checked.
Mar 02, 2009 | LG ALLTEL AX275 Cellular Phone
When i plugin chargar mobile show usb connect
Insert your charger pin completely into the phone. Then phone will show charging now.
After also if problem not clear then you have to reset the seetings and try it again.
Thanks,
Rokr_E6
Jan 12, 2009 | Motorola Mobility ROKR E6 Smartphone
NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
Feb 16, 2008 | Nokia 6630 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
198 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
