Question about GE Profile Prodigy WPSE4200A
Reattached tub, but spin cycle doesn't work
During "final spin" the tub became detached and was wobbling badly. I paused the machine, unplugged it, removed the front panel, and was able to reattach the tub to the corner rod. However, when I replaced the front panel, and plugged the machine in, and pressed the start button, with the selector on "Spin Only", the machine starts up and sounds like it is trying to run, but nothing is happening inside. Did I forget a step when I reattached the tub?
  • 1 more comment
  • skupping Dec 12, 2007
    The belt looks fine.
  • skupping Dec 13, 2007
    The belt is fine but the tub doesn't spin.
    I looked again and turned the machine on "Final Spin" with the front panel off. I noticed the pulley jerking slightly, and got a closer look. I could see the motor shaft above the pulley spinning at its normal speed, but the pulley wasn't moving.
    I turned off the machine and unplugged it and looked at the motor shaft and pulley again. I noticed a pin through the motor shaft, just above the pulley. I had a flashlight and could see where the pin fit inside the clutch which is inside the pulley. I raised the pulley up and the clutch allowed the shaft pin to sit into its "cutouts" as the pulley raised into place.
    I looked around to figure out why the pulley was able to move up and down along the motor shaft freely, and noticed the clutch retaining clip by itself on the bottom. I pushed the pulley up into place and put the clip below it onto the shaft at the bottom to hold the clutch and pulley in place, and the washer is working again.
    So, apparently the wildly wobbling tub knocked the clutch retaining clip off which let the pulley slip down the motor shaft, to the point where it dropped below the shaft pin, so that the pulley wouldn't turn anymore.
    Thanks for pointing me in the right direction, hopefully this is helpful for others, or at least, something to check if they have spin problems.
    Sergeant:
    Champion:
  • 362 Answers
The belt might have come off of the tub take it back apart and look underneath and see if the drive belt is loose or on the floor when the tub came loose it probably slipped the belt off before stopping.
Posted on Dec 12, 2007
  • james kilgore
    james kilgore Dec 13, 2007
    ok now if you look underneath there is an attachment that looks like a trailer hitch with a arm attached to it this drives the tub from the pully hook up where belt attaches. the connection there breaks and causes the tub not to work. if you see it they cost about 20.00 and its a fairly simple replacement and it comes with instructions on how to install, the piece you will look for is usually above the belt but if you see the attaching arm loose you wont miss the part.
My Duet Washer is making loud noise during spin cycle and has plastic shavings, from front tub rubbing i assume.
Hi, it could be your drum bearings are gone the drum would wobble slightly. A way of checking is , machine unplugged put one hand at bottom front and one hand at top front edge and push up and down if it clunks quite badly then your bearings on the drum shaft are needing renewed. You also have a shock absorber for steading the drum this can also fail. The absorber is very hard to compress so if its easy to compress then it needs re-newed.
Dec 29, 2015 | Washing Machines
Rattling noise in spin, spin problems becoming more pronounced. control panel lights flash but 0 error codes. unplug 2 reset, probl repeats
If this noise is happening while it's trying to drain water then you have something floating around in the lump. Coins are very common. If the noise is happening during a spin cycle and more pronounced during the final high spin cycle, you have bearing or spin tub issues. Time to go shopping.
Nov 07, 2013 | Frigidaire ATF6000ES Front Load Washer
Washing machine won't spin
Sounds like corrosion in the motherboard . Get an electronics serviceman to take a look, could just need soldering point to point connection. Hope this helps.
Jan 14, 2013 | Washing Machines
Is water supposed to enter the tub during the first half of the final spin cycle (not rinse cycle)?
no spin cycle don't have water it could be the pump is not getting the water out fast enough, could be clogged or the rear drain pipe is blocked or bent. failing them to problems it could be the valve its self.
Aug 04, 2017 | GE WBSE3120B Top Load Washer
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
During spin cycle on every load the machine is wobbling around as if it was out of balance. The machine is level. I have the front off but dont see any issues.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 13, 2010 | Washing Machines
Washing Machines Logo
135 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
