Question about Nintendo Wii Console
Wii controller Cannot get controller to register with console. All 4 blue lights flash when any button on the controller is pressed. Have replaced batteries, Tried to sync.
  • MrPig Dec 12, 2007
    I'm having the same problem, too. None of my Wii remotes will register with the console, and I've done everything.
  • 140 Answers
Check sensor bar position and connection.
try this at night, to avoid sunlight hitting sensor bar.
turn the console on, open front panel, press sync there.
with controller turned off, open battery cover and press sync there.
remember. with controller turned off.
if doesn't work call nintendo for a help or replacement.
Posted on Dec 12, 2007
Remotes won't connect. put in new batteries, tried pressing red button in side remotes, all 4 blue lights are flashing on both remotes
Hello kellyanne_ma,
The Wii must be searching for remotes before one will connect. If you are trying to connect controller #1 (meaning there are none connected) and it fails, there may be a problem with your Wii.
First, remove power from the Wii by unplugging it. Wait 30 seconds and then plug it back in. Once powered on and you see the health/safety information press and hold the red SYNC button on your Wii for 20 seconds.
Now press the Sync button on the controller and while the blue lights are flashing, press the Sync button on the Wii.
Hopefully, that will connect the controller! If it does not, you may need to contact Nintendo!
Jun 28, 2011 | Nintendo Wii Console
I can't connect my controller to the wii console. Model number Rvl-001(USA). Model of nyko pistol accessory is Bn:090907 4632.My mom threw out the manual out by mistake.HELP!
  • Turn on your Wii console. While on the HOME screen, press any button on the Wii Remote.
  • If the 4 squares on the bottom remain dark, change the batteries (or for a rechargeable Wii Remote, place it on the charger for a while).
  • If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
  • If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
  • Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console.
May 13, 2011 | Video Game Consoles & Games
When sychronizing the wii balance board we held the sychronize button down to long and now the wii remote control won't work how do we fix this
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
3. Open the small SD Card slot cover on the front of the Wii console.
4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
7. The blue light will stop blinking and stay on steady once the synchronization is complete
Click here to download repair guide
Jan 05, 2011 | Nintendo Wii Console
How do i resync my wii controler
follow the steps descrived below:
1.Turn on your Wii console. While on the HOME screen, press any button on the Wii Remote. If the 4 squares on the bottom remain dark, change the batteries (or for a rechargeable Wii Remote, place it on the charger for a while).
2.If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
3.If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
4.Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console.
Mar 03, 2010 | Nintendo Wii Console
What does blue flashing on the nunchuck
this is what happens when the device attempts too connect to the console. the solution is very simple as well. simply remove the battery cover on the the wii-mote. now open the memory card door of the front of your wii. note the red button on both the wii and the wii mote. now simply press and hold both and then the wii mote should automatically pair to the console. repeat whenever needed. Hope i was a help to you today.
Mar 17, 2009 | Nintendo Controller add-on Nunchuck for...
Remotes don't seem to register with gaming system
Before Pressing the Red Button inside the Battery Compartment. Make sure to open the Small "Door" on the Front of the Wii and press the Small Red "Sync" Button first and then Press the Small Red Button inside the Battery Compartment. You should hear a "beep" to confirm that your Wii Remote has been reconnected.
I hope this helps. Take care =)
Dec 08, 2008 | Nintendo Wii Console
When new batteries have been put in both controllers of the wii, indicator lights supposed to indecate power level of batteries instead of which all blue lights flash then stop and nothing happens, no...
If all the lights are coming on then going off again the controller needs to be synched with the wii. Once it is synchronized after all the indicator lights flash one should stay on indicating which player you are (1 -4)
To synch a controller to the wii:
Make sure the wii is in
Open the battery cover on the wiimote
Open the front panel of the wii
Press the synch button on the console
Press the red synch button on the wii mote
Should work for you.
Jul 04, 2008 | Nintendo Video Game Consoles & Games
Wii remote
Hey did you try holding the red button where you put the batteries and holding the red button where you put the SD card all unit have an button so it can read the sensor from unit to controller....
Jun 21, 2008 | Nintendo Wii Console
Discs wont register on wii system, remote wont work either
You need to sync the remote with the console.
Remove the battery cover from the remote and press the red
button until the blue lights start to blink. At the same time,
press the the red button to the front of the console.  You
can access this button by removing a small cover on the front
of the console. This will reset the machine and you should
start to see th cursor in the tv screen. Repeat this if necessary
and you should be on your way. Good luck
Sep 25, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
110 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
