Question about Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH
Encore 802.11 g wireless router
I am have trouble connecting to the internet, using the router. If I by pass the router and connect directly to my computer I have no trouble. My provider says the router is holding the old IP address. When I use the repair on my computer, it gives me an error of- trouble clearing ARP cache. Any ideas?
thanks,
Lisa
  • 556 Answers
Generally routers can be configured using a web browser. But first we need the manual for the router to know what we are doing. Using the router link below look on your router and try to match the model numbers in red on the left under wireless with your router. If that does not work try matching with the contents of the select a product drop down list box in the top center of the window.
Router link
Second -- assuming this router is had a previous owner or was used in another location we need to get access to the router.
If the router currently does not work with your current ISP as indicated you may want to reset the router using instructions from the manual -- reply to this message if you need help.
If you believe the router may contain useful information we need to try to get the router's IP address.
Assuming your computer runs windows XP try this. --
Connect the computer to the LAN (not WAN) portion of the router -- this is probably 4 consecutive ports to plug cables into. Power up both the computer and the router (not connection to the internet required.
Click on Start
then All Programs
then Accessories
then Command Prompt
type -- ipconfig -- (8 letters) and press enter.
Report the resulting display of one or more adapters, ip addresses, subnet masks and default gateways here Iand I will help with the next step.
If you can provide a web link to your ISP's help site -- we will probably be able to conffigure the router for your use with your ISP.
Thanks
Posted on Dec 11, 2007
I installed this router on repeater mode, connection to existing router and signal is perfect but have no access to internet... in the access router the internet access is perfect. please let me know how I...
this is from Encore-usa.com
How to use ENHWI-N3 / ENHWI-N34D / ENHWI-2AN3 / ENHWI-2AN34D / ENHWI-3GN3 as a Repeater?
  • For Advance Users, you can download this document.
  • The reason why people use a Encore wireless repeater is because some wireless remote client computers are out of range from the main network's access point (wireless router), or the wireless client is in the dead spot or the device you want to share to the network have no wireless interface card.
    The function of a wireless repeater is basically to extend the wireless signal coverage. Wireless repeater does not authenticate, screen, secure, connect to the internet, give IP address to clients, broadcast names, etc., these are the wireless router's job. Repeater only repeats what the main wireless router does to the wireless clients.
    Checklist:
    • You should know the wireless security type of the existing wireless AP/router, is it a WPA, WPA2 or a WEP?
    • The wireless security key, or password or passphrase of the existing wireless router
    • Your existing wireless router's SSID
    • We recommend that the existing network you are about to add the Repeater on have a DHCP server running and able to lease IP address to all network clients. If you are not sure about this, please ask your ISP or the person who installed your network.
    Hardware Checklist:
    • Computer with wireless device turned off. This is only to set up the repeater, once finished the wireless can be turned on again.
    • The computer must have an available RJ-45 network interface card and web browser installed.
    • A working wireless router or Access Point with one available RJ45 port
    • RJ-45 UTP/TP Ethernet LAN Cable
    • The Encore Router is set to factory default. If your Encore Router is brand new and just pulled out of the box, no need to reset. If changes were made to any settings to the Encore Router before, make sure you "hardware reset" the Encore Router to the factory default settings. Check the User's Manual on how to "hardware reset" the router.
    PROCEDURES:
    1. Hooking up hardware connections:
    1. Both PC or Laptop and the Encore Router should be turned-on.
    2. Disable the wireless client from your PC or laptop computer (if not done so)
    3. Connect the Ethernet cable to the PC or laptop computer and the Encore Router. (This can be done while PC computer and router are turned on.)
    2. Switching mode from AP Mode to Repeater Mode
    1. Using your computer's web browser such as Internet Explorer or Safari Firefox, enter 192.168.0.1 to the address field then hit enter. You should see the Encore Router's User Interface screen still in the AP Router Mode
    2. On the upper right corner of the user interface menu, click on the drop down menu and select "Repeater Mode". Click the "OK" button to the warning box. Wait around 35 seconds until your screen comes back to Encore user interface screen, this time the screen is now in the Repeater Mode. If for some reason you were asked by the repeater to enter the username and password, enter the default username and password (admin/admin) and your Encore Router is now in Repeater Mode.
    NOTE:
    As of this moment your repeater is not connected to any router or network. It has to be configured further to be able to be connected to your current network and access point router.
    3. Connecting your Repeater to your existing network access point or router:
    1. As soon as the Encore Router switched to the Repeater Mode, you should be able to see the same Utility Screen with fewer selections on the left pane.
    2. From the Main Menu screen click on "Wireless" located on the left pane.
    3. Click on "Site Survey" button, a new Window dialogue box will pop up showing a list of Access Points reachable by your Repeater
    4. Check your existing network's access point SSID then click on the radio button that corresponds to your access point router then click "Connect" button.(If you can't find your existing AP router, click on "Refresh" repeatedly until your access point show up, or your location is too far from your existing AP router).
    5. Click on the "Encryption" drop down menu, select your existing access point wireless security, enter your existing router's wireless security key or passphrase then click "Apply". If you get a FAILED message, repeat this procedure again, a wireless hiccup might be interfering, otherwise you now have a working Repeater.
    6. Check your repeater connection by going to your internet browser and open a web page of your choice. If successful your new wireless repeater is working.
    7. Disconnect the Ethernet cable and setup your computer back to its original wireless settings. At this stage, the Repeater is now invisible to any wireless client computers. When connecting a new wireless client within the repeater's wireless range the process is the same as there is no Repeater device at all, the SSID of the wireless router will just be extended in range around where the Repeater is physically located.
    4. Connect your remote wireless client to your wireless router
    1. Using your wireless client utility program, look for your existing router's SSID and connects to it, if this is a new client you will be prompted with the wireless security key. Your repeater is invisible to all wireless clients. All it does is to repeat the wireless router signal as it is to extend its range. Once you have converted the Encore Router to Repeater and successfully connected to your existing router there will be no more configuration needed to the repeater. If you happen to see two identical SSID's of your existing router, this means your wireless client is within the same range of your existing router and the new wireless repeater, then your client don't need the repeater's service.
    NOTE:
    If you are using Windows 7 and your existing access point security wireless is set to WPA2 (AES), make sure your Windows 7 wireless security type properties is set to WPA2-Personal. To check go to Windows 7 Wireless Network Connection, look for your REPEATER router, right-click on it then click Properties, check the settings in the "Security" tab.>
    NOTE:
    When checking the wireless site survey, you may see two routers with the same SSID (names), these are your Access Point and the REPEATER tied together. This also means you are within the reachable range of both Access point and REPEATER.
    5. To check the Repeaters user interface
    At this moment, the Repeater is invisible to any client. The client's IP address is drawn from the DHCP server most likely to be also your wireless router. Therefore the IP address of the repeater is also invisible to the clients. Follow steps below:
    1. Disable wireless connection or turn off wireless in the client PC computer
    2. Connect Ethernet network cable to the RJ-45 port of the client PC computer
    3. Connect the other end of the Ethernet cable to one of the LAN ports of the repeater.
    4. From your computer, set the network card IP address to Static IP Address entering 192.168.0.102, Subnet Mask 255.255.255.0, leave the rest as blank.
    5. Open IE or Internet explorer or any other web browser software and run 192.168.0.1, you should be able to see the Encore Repeater user interface screen. (Changing any settings in the repeater may affect its performance)
    That should help :)
    Christopher
    May 15, 2012 | Encore Enhwi-2an3 Wireless-n Router
    I need to set a password on my router so no one else can acsess it
    Hi coachman2526,
    I would like to help you with your concern regarding your Wireless Routers password / security.
    I believe that when you say password on your Router so no one else can access it that you mean no one will be able to get internet connection from your Router is that correct?.
    Follow these steps below to secure your Wireless connection to prevent others from accessing your Routers Wireless signal.
    * First open your Internet Explorer browser, clear the address bar and type in your Encore IP address which is 192.168.1.1 then press Enter on the keyboard.
    * Once you have the Encore settings page, click on the Wireless tab on the left of the settings page.
    * In the Wireless settings select enable on the wireless, and on the SSID you change it to your name so you can detect your router once you connect wireless.
    I hope this will be helpful regarding your concern.
    Have a nice day,
    mvincentc
    Apr 15, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
    I have a laptop running 802,11 g/b and vista and I Cant connect to linksys wag160n wireless router(802,11 n). laptop sometimes recognises network but when I try to connect it wont. could you help ?
    Hi, You cannot connect across wireless protocols. In other words to connect to 802.11 n you need an "n" adapter.
    Now, the router should be backward compatible & provide wireless g/b but you may find that when you search for networks it will be listed as a seperate network name (from the same router)
    Try searching for this other network. Your router documentation should advise you of its default name & any set up process
    Dec 23, 2009 | Acer Computers & Internet
    Problem with Encore 802.11n Wireless Router ENHWI-N2
    Well a router that supports 802.11n will also support g.
    In any case I am under the impression that your DNS settings might be wrong.
    A good router to look at are D-Links, I have been using the DIR-655 for my house see: http://www.dlink.com.sg/products/?idproduct=21&idCategory=175
    Enjoy
    Nov 30, 2009 | Encore ENHWI-N Router
    Can't connect to the internet
    Try to disable any firewall you have on your computer like windows firewall or any third party firewalls like zone alarm, norton and mcaffe
    May 09, 2009 | Encore 802.11G WIRELESS LAN ROUTER...
    Internet connection speed of the Encore ENHWI-G2
    if you're router is in the B+G setting, try setting it to the B setting, this is because the wireless adapter in the i-phone/i-touch uses only the B setting, sucks for most part.. but that got my i-phone working like a charm.. hope this helps
    Jul 16, 2008 | Encore 802.11G WIRELESS LAN ROUTER...
    Communication trouble
    What kind of router do you have? Are you using wired or wireless ethernet to connect through said router?
    Mar 21, 2008 | Encore 802.11G WIRELESS LAN ROUTER...
    Belkin wireless g router 2,4 ghz 802,11 g
    Whats the model number of this Belkin router?
    Oct 16, 2007 | D-Link DI 514 Wireless Router (DI-514)
    Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH Logo
    197 people viewed this question
    Top Encore Computers & Internet Experts
    Michael Galve
    Michael Galve
    Prashant M
    Prashant M
    Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
