Question about Lexmark P3150 All-In-One InkJet Printer
Door top the printer says lid is open when its closede i think something broke off what can i do to make it print?
  • Lexmark Master
  • 1,113 Answers
Google is your friend, here is the solution I found from the web.
You might want to just shove something in the hole to make switch stay closed or...
I finally got brave and opened my unit up to find that there is a presure switch in the back right corner. The printer door presure switch is in the back right corner. If you lift up the printer door you will see a light gray angle piece that goes down into the printer from the scanner bed. That is where the presure switch is. Most likely the little black rocker arm (it's about one inch long) came lose fromthe switch. You need to reseat the arm.
You have to remove the scanner cover door.
Then lift the printer door up and to the front left the red support needs to be disconnected from the Scanner bed. This is done by squeezing the top of the support until it releases.
Then you need to release the scanner bed from the printer. With the printer door up, look to the back right you'll see a light gray stop sticking down into the printer bed. Gently push that to the right and the scanner bed will be released from the printer. (It will have a little hook on the end.)
Now you can get at the two screws in the back corners of the top of the printer. Remove them and the two frot corner screws.
There are little tabs holding the top of the printer inplace. You need to work the top out of the tabs. Watch out for the 3 ribbon cable in the back right.
Move the top up and out of the way and then you can see the presure switch on the board to the back right. There should be a rocker arm pointing straight up so the scanner bed will hit it.
I had the very same problem. It was very tricky getting the plastic lids and other plastic items apart and then back together successfully. Using a small, straight screwdriver edge was helpful as a prying tool to separate the lid fingers from the plastic base.
Also, having a second person to assist was critical in order to feed ribbon cables back through lid and holding the scanner assembly at the same time. A great deal of patience and trial-and-error attempts are required. Using a very intense light source and a large magnifying glass or viewer will also help.
The black rocker arm fits on top of a very, very small microswitch that is mounted on the vertical circuit board. Lining up the lid with the gray, beveled device that contacts the black rocker arm should show you how to align the rocker arm.
This design indicates just how sloppy design manufacturing has become over the years ... all in the name of low-cost. Good luck to the rest of you Lexmark printer owners!
Posted on Dec 28, 2007
HP 6500 open door error
I would lift the top up...and on the back left corner is a slot that the tab from the lid goes into to say the top is closed, I would stick a piece of paper of cardboard in the grove, or slot and see if that works..I think it is a light beam type switch, and not a mechanical switch that telsl the printer the lid is down..so you basically blocking light when cardboard is in that slot...
Kenny
Mar 31, 2014 | HP Officejet 6500 Wireless All-in-One...
My HP 870cse thinks that the top is open and will not print. In-fact the top is closed. Is this fixable?
Dear friend,
There is a sensor on the mech assembly that pushes it on closing.I think it just something dismatled or mis aligne.Check with that.You can see the sensor just by opening the door.Hope i'll help.
Mar 07, 2011 | HP DeskJet 870cxi InkJet Printer
Lid at printing end does not seem to fit rite....must press down on right side to restore printing. As long as you retain the pressure, it continues printing.
Do you mean that you need to retain the pressure to have good print quality on the right side or you need the pressure to keep the amber status light from showing ?
There is a small optic sensor that functions to indicate if the lid is open or not. The printer will not print as long as it thinks the lid is open. If the lid won't snap down tight enough you can fool the printer by placing a small piece of label or something opaque over the sensor to make it think the lid is closed. The sensor is located on the right side just behind the green adjusting wheel used to adjust the label width guides.
Hope that helps...
Apr 15, 2010 | Zebra Eltron LP 2824 Thermal Printer
Printer stopped printing; amber teardrop is flashing; no paper jam; cartridges should not be empty. Shouldn't there be a notice of low ink before it just stops printing? Or, the printed pages be faint? All...
The top access door on the printer might be open, or there might be something wrong with the print cartridge.
  1. Check to make sure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door opens, the print carriage moves so the yellow arrow on top of the print carriage points to a drawing of a cartridge inside the cover. Each drawing describes a symptom.
Jan 09, 2010 | HP DeskJet 5550 InkJet Printer
I have a hp 5150 desk jet that won't print. The task manager says "door open" which I see sometimes after I change out the cartridges. However, in this case I didn't. I've opened and closed everything...
Open the printer cover.From right side there is a plastic rod.It's connect to door sensor.This plastic rod often breaks from top.Look that and if it's broke try to fix it with glue or something else.
Nov 20, 2009 | HP DeskJet 5150 InkJet Printer
Top Load making noise. Wash cycle finished, open
bad lid switch.coupling broke and rubber burning or trans locked up
Nov 15, 2009 | Refrigerators
I just changed my printer cartridges and I'm trying to print but I keep getting "door open" or "top cover open" message and nothing prints. My printer is a HP 5150
Open the cover.In right side you'll see the cover sensor.It's a plastic lever, which does down to the bottom of printer.The top side of this lever usually breaks.
Oct 13, 2009 | HP DeskJet 5150 InkJet Printer
Printing (text suddenly blurry bold after closing lid).
open the toner access door remove the toner, slowly lower the tone access door and ensure that the top roller (charge roller) is lowering straight. the roller in the bottom of the cavity (the transfer roller) push down on this to ensure that it has spring tension. if the top one is level and the bottom one has tension then you'll need to change the high voltage power supply.
Jan 15, 2009 | OKIFAX 5780 All-In-One Led Printer
Deskjet 5650 broken door latch
I have seen this problem with this series of printer. (all the ones shaped like this ie. 5150) The lid will not close all the way on the right side (this is where the lid triggers the door open/close sensor flag). Somehow the sensor flag gets out of alignment over time where the top can't close properly to trigger it. The simplest solution is take something and wedge it where the tab from the lid would come down and make contact with this sensor flag. Print with the lid open or set the lid down on whatever you use to trigger the sensor flag. Hint: when testing and problem solving in house, I use a small piece of paper folded up several times to trigger door open/closed sensors that way I can watch the printing process and diagnose problems.
Inkworks
866-381-0541
Nov 03, 2008 | HP DeskJet 5650 InkJet Printer
Printer Door
I have that exact problem at work. There is a bump on the right side of the lid...and when you close the lid it presses on a lever. Check and see that the bump actually pushes that lever downwards. That's how the printer determines that it's closed.
Feb 03, 2008 | HP DeskJet 3650 InkJet Printer
Lexmark P3150 All-In-One InkJet Printer Logo
89 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
