Question about Pentax Optio 50 Digital Camera
No view on the screen
I was taking a pictures and when I finished I shut off the camera and put inside my car. Next time when I started to take pic. there is no view and the screen gets black
  • very_annoyed Dec 31, 2007
    Exactly the same thing has happened with me - I was on holiday, taking lots of pictures, then on the last day I turned on my camera and the screen was completely black. It still appears to 'take' photos, but they are black too. All the menus etc work - there's just no picture!
    I don't know if it's worth trying to get this fixed or if it would be cheaper to bite the bullet and get a new camera - I would be grateful for people's advice.
  • Smokeyjoe65 Apr 21, 2008
    I was using the camera one day then turned it off. The next day I turned it back on and could not get the images I wanted to shoot in the display. Display was totally black. I changed batteries several times, but that did no good. I proceeded to take pictures looking through the small viewfinder, but no pictures came out.
I was lucky to have this happened on th efirst month. They replaced it with another camera that is eating batteries like crazy.
Posted on Feb 02, 2008
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
--cannot view anything to take a picture of--the view screen is black but I can see al menu items and can display settings. Flash works. I can see cannon signal clearly when camera is turned on. I am...
The A6XX series is prone to stuck shutter problems, particularly if the camera isn't used very often. Lens lubricating grease can coagulate on the shutter, immobilizing it. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 29, 2011 | Canon PowerShot A630 Digital Camera
When I turn on my Canon PC 1130 to take a picture, the lcd screen and view finder just show a black screen. Camera is working fine in the play mode. Please help.
Set the camera in TV mode, (delayed shutter mode) set the shutter at 15 sec, click to take a picture and during that 15 secs (like, after 7 seconds) open the battery compartment which cuts contact with the battery circuit. Close the battery cover. At this point the camera works fine ... but only temporarily.... Here is the key to the permanent fix. While the camera is working via the temporary fix, take many, many pictures. Hundreds! I probably snapped 400-600 pics. The idea is to wear down the little patches of hardened oil on the shutter blades. For the next three days I took hundreds of pics each day. Basically, I just aimed the camera at the wall or whatever and snapped off several hundred pics.
Jan 05, 2011 | Canon Cameras
When I try to boot up it says windows did not start properly and it just keeps rolling this screen. It flashes to the windows xp for a second and then goes back to the screen saying it did not start...
Try restore pc to factory setting. here is the way : http://support.gateway.com/s/software/microsof/Vista/7515910/7515910su12.shtml
Or follow this without picture is the same info:
Restore from Factory Default
The Factory Default installs a new copy of Windows Vista™ on the computer. The installation restores the computer back to the factory installation of Windows Vista with all the drivers and programs that originally came with the computer.
Notes:
  • Be sure that you back up your data files before performing this option. All of your personal data files and applications are erased during the recovery process.
  • Due to the large number of virus and Spyware threats on the Internet, it is recommended that you disconnect all Internet connections before performing the recovery. After the recovery, antivirus and firewall software can be installed, and then the Internet connection can be re-enabled to update the antivirus definitions and perform Microsoft® Windows Updates.
  1. Remove all CDs or DVDs from the optical drives.
  2. Turn off the computer, using the normal Windows shut down process.
  3. After the computer is turned off, disconnect all USB devices except the keyboard and mouse. This includes USB devices such as a printer, scanner, removable storage, or camera.
  4. Turn on the computer. After the Gateway BIOS logo appears, press ALT+F10. The easiest method is to hold down the ALT key and repeatedly press the F10 key. Note: There is no prompt to press Alt+F10.
  5. Windows loads files.
    View Picture
  6. The Please wait a moment screen is displayed.
    View Picture
  7. In the Restore from factory default dialog box, click Next.
    View Picture
  8. In the Destination Disk Information dialog box, click Next.
    View Picture
  9. In the Notice dialog box, click OK.
    View Picture
  10. The hard drive partition is created.
    View Picture
  11. The factory default installation is copied to the hard drive.
    View Picture
  12. In the Finished dialog box, click OK.
    View Picture
  13. The Please wait a moment screen is displayed and the computer restarts.
    View Picture
  14. Windows prepares to start for the first time. This may take a few minutes.
    View Picture
  15. Windows continues setting up the computer.
    View Picture
  16. The computer restarts.
  17. In the Set Up Windows screen, click Next.
    View Picture
  18. In the Please read the license terms screen, select the I accept the license terms check box for each item, and then click Next.
    View Picture
  19. In the Choose a user name and picture screen, enter the appropriate information, and then click Next.
    View Picture
  20. In the Type a computer name and choose a desktop background screen, enter the appropriate information, and then click Next.
    View Picture
  21. In the Help protect Windows automatically screen, click Use recommended settings.
    View Picture
  22. In the Review your time and date settings screen, select the appropriate settings, and then click Next.
    View Picture
  23. In the Select your computer's current location screen, click the appropriate option.
    View Picture
  24. In the Thank You screen, click Start.
    View Picture
  25. Windows checks the computers performance. Depending on hardware, this process can take up to 15 minutes to complete.
    View Picture
  26. Windows prepares the desktop.
    View Picture
  27. The Gateway Recovery Management is installed.
    View Picture
  28. Installation is complete.
Dec 23, 2010 | Gateway LT2001u Netbook
New pictures I am taking with my camera are showing up completely black. I can view previously saved pics on the SD card on the screen, but any new pics only come up black. Any ideas what this could be?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Feb 21, 2010 | Canon PowerShot S2 IS Digital Camera
My fuji finepix s5600 has stopped taking pics,just as i put new batteries into it,i can look at previous photos that i took,but it just wont take the pics,why?
Is it showing any message on screen as to why it won't take pictures or is it when you switch over from viewing to taking pics that it shuts off or just won't let you take pics?
Jan 07, 2010 | Cameras
I would like sto dump my system, and start over. Syst: Gateway GT5220. running Windows XP service pack 3
this will perform an install that will eraseeverything and start over.
  2. Turn off the computer using the normal Windows shut down process.
  4. Turn on the computer. To start recovery, at the prompt press the F11 key.
    View Picture Note: If this is the first time the computer has been started to the recovery partition, insert the System Restore CD when prompted and then click OK.
    View Picture Files copy.
    View Picture
  5. In the System Restore Options dialog box, select Full System Restore (Destructive), and then click Next.
    View Picture
  6. In the System Restore - Format and Recover dialog box, click Yes.
    View Picture
  7. Files copy.
    View Picture
  8. In the System Restore dialog box, click Restart.
    View Picture
  9. The computer restarts.
  10. Drivers and applications are installed.
    View Picture Note: The following Out of Box Experience (OOBE) screens may vary slightly between models.
  11. In the Welcome to Microsoft Windows screen, click Next.
    View Picture
  12. In the Are your speakers working? screen, click Yes! I can hear the music!, and then click Next.
    View Picture
  13. In the What time zone are you in? screen, select the appropriate time zone, and then click Next.
    View Picture
  14. In the End User License Agreement screen, click Yes I accept for both EULAs, and then click Next.
    View Picture
  15. In the Help protect your PC screen, click Help protect my PC by turning on Automatic Updates now, and then click Next.
    View Picture
  16. In the What's your computer's name screen, type a name for the computer and a description, if desired, and then click Next.
    View Picture
  17. In the What's your Administrator password? screen, type the appropriate information, and then click Next.
    View Picture
  18. In the Is this computer in a domain? screen, click Skip.
  19. The computer checks the Internet connectivity. Please wait.
    View Picture
  20. In the How will this computer connect to the Internet? screen, select the appropriate option, and then click Next.
    View Picture
  21. In the Do you use a username and password to connect to the Internet? screen, select the appropriate option, and then click Next.
    View Picture
  22. In the Setting up a high speed connection screen, select the appropriate options, and then click Next.
    View Picture
  23. In the Ready to register with Microsoft screen, to register with Microsoft after the OOBE screens are completed, select No, not at this time, and then click Next.
    View Picture
  24. In the Thank you screen, click Finish.
    View Picture
  25. Installation is complete. Any application that shipped on a separate CD can now be installed. It is recommended to update the antivirus definitions and perform Windows Updates.
Oct 06, 2008 | Gateway Computers & Internet
THE LCD SCREEN IS BLACK AND I CANT TAKE A PICTURE. BUT I CAN STILL VIEW MY PICS. THE CAMERA GOES THRU ALL THE MOTIONS LIKE IT IS TAKING A PICTURE BUT IT IS JUST COMING UP BLACK.
The LCD screen is black and I can't tace picture. But I can still view my pics. The camera goes thru all the motions like it is taking a picture but it is just coming up black.
Aug 31, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Takes forever to take multiple pictures
My camera has different "modes" and if I put it in the "action" mode it seems to work more quickly between pics. There should also be a setting to change how long the pictures is displayed after taking, if you shorten that it will recover quicker to allow the next picture taking.
Jun 08, 2007 | Nikon Coolpix 4600 Digital Camera
Camera shuts down when I go to take pic mode
Ahhhhh! I have the same problem occuring!! I cleaned all of the battery terminals and replaced the batteries, and STILL have this problem, although not as frequent. It always happens when I take the best pics, the image shows on the screen for a fraction of a second, and then the whole camera shuts off. Again, I can play back images with no problem. What's the deal here?? It's become so frustrating that I just want to throw the camera in the garbage. It has been such a good camera up until this point. PLEASE, someone help us here!!!
Aug 30, 2006 | Fuji FinePix S7000 Digital Camera
Pentax Optio 50 Digital Camera Logo
90 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
