Kenmore washer # 11092591220 not working
The unit will not agitete for the wash or rinse cycle. it also will not spinnduring the sin cycle . went under machine and found what appears to be black rubber filings from small rubber drive wheel. help please
My washer agitates, but will not spin or drain. I checked the hoses and belts which seemed fine. Could it be the pump or the lid switch?
Posted on Sep 23, 2008
Omg kick it some what it should work!
Posted on Dec 11, 2007
  • 89 more comments
  • lololol Dec 11, 2007
    KKKKKK
    KKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    KKKKKKKKKK
    DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!! DID IT WORK???!!!!
Star washing went get to rinse circle stop, press stop bottom and start bottom tries to start but not work
if you're saying it dies in the rinse cycle you could have a problem with your cold water not coming into the washer,the washer only uses cold water in rinse cycle,no cold water the washer won't run,try starting it just with cold water and see if it fills,if not bad water valve or problem with water in house valve or bad hose.
Apr 08, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not go to the rinse cycel.
check cold water line...onthejob,,,im assuming no rinse cycle only..onthejob,,,no mater the cycle
Jan 31, 2009 | Kenmore Elite 45986 Front Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
