Question about Lexmark X1270 All-In-One InkJet Printer
Not printing my printer will not print. i have a x7170 lexmark it keep saying that trying to connect and sometimes it says the ink cartridge are in the wrong slots. i have ink. please help
My printer is not installed
Posted on Dec 28, 2007
Lexmark X7170 will not print in grayscale
i have cannon 3530 xerox machine ... it shows error code 350 ?? any solution ??
Jul 28, 2013 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark x7170 changed ink cartridge. test sheet comes up great, print something and it says ink low. i tried to shut off 5x's to maybe reset/ reinstalled ink cartridges same message. cleaned heads
The Lexmark x7170 should let you continue printing with the ink cartridge regardless of the estimated ink with most cartridges. The only exception to this is if the cartridges are part of Lexmark's returns programme. I would advise removing the cartridge and checking for small text stating "Return Programme Cartridge" on the label. If this is present sadly there is no way of continuing, apart from buying a new cartridge.
With regards to the low ink estimate, am I right in assuming you are using a refilled or remanufactured ink cartridge? If so this is unavoidable but should not prevent you from printing until the ink physically runs out.
Nov 29, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
My lexmark X7170 Printer Skip line when printing how do fix it
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
Jan 03, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
  2. Go to Programs.
Replaced new ink keeps saying right cartrige is incorrect wont let me print. the cartrige is correct i paid $50.00 for a two pack of black and color ink!!!
Wiping the nozzles with a moistened soft cloth or removing and reinserting the cartridges usually helps. The cartridges for the Lexmark X7170 are black: 32/34 and color: 33/35. If these are the cartridges that you purchased and even tried your old and new cartridges yet the problem persists, please don't hesitate to contact Lexmark technical support.
Mar 23, 2011 | Lexmark X7170 All-In-One InkJet Printer
Ink cartrige problem i replaced both cartriges keeps saying right cartrige is incorrect wont let me print
Mar 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have lexmark x7170 all in one printer and i can't receive faxes it says memory full but when i try clearing it it says no pending faxes so i cam't. What can i do?
This temporary storage of fax may happen when one of your cartridge is detected low ink level. Try to replace your low ink cartridge. Sadly, if you have navigated away from the fax menu after inserting a new cartridge or clearing the message, you may lose the fax. You can try to have the sender resend the message. When this problem happens again, just replace your cartridge without turning off your printer. Once inserted, accept the incoming fax message to print it.
Feb 16, 2011 | Lexmark X7170 All-In-One InkJet Printer
I have a Lexmark x7170. After installing ink cartridge printer says incorrect left cartridge.If you try to print you get unsupportive cartridge.We had just changed the cartridges and it printed fine till...
Some older print cartridges are not compatible even if your model is listed on label. I'm talking a few years difference. The printer knows this and that is what the error is telling you. Make sure you have the right number in the right slot.
Jan 06, 2011 | Lexmark Office Equipment & Supplies
Error:2200
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 13, 2009 | Lexmark X7170 All-In-One InkJet Printer
Mono color
These models use a "3 colour" printing process. In other words, these printers do not contain black ink when the BC-05 colour cartridge is installed. To produce black print, a 3 colour printer mixes an equal amount of the three primary colours. This process is known as "composite" black.
As the ink in the cartridge runs out, one of the three primary colours will run out first, depending on the material that has been printed. After one of the three colours has depleted, this colour will be missing from the mixture required to print black, and the print will change colour. This is the indication that the cartridge needs to be replaced. Usually the remaining colours in the cartridge will run out soon afterwards.
Rate the solution as appropriate !
Feb 07, 2009 | Lexmark X7170 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
