Question about Toshiba MD19N1 19 in. TV/DVD Combo
Remote control users manual needed
Trying to find a users manual part number dc-sb1 for my toshiba tv/dvd combo. closed captioning is on want to turn off.
Judy
  • 2 more comments
  • Anonymous Jan 07, 2008
    Closed caption is on. I want to turn it off. Please help.
  • lynneha Feb 19, 2008
    I have the same problem.  I think I pushed a button accidentally and now I can't get off the closed captions.  The closed caption button on the remote doesn't seem to do anything.  I have tried menu etc.
  • Anonymous Feb 22, 2008
    can't get it off!
  • tandvfischer Sep 16, 2008
    I can't get rid of closed captioning either.
I had this problem just now for the Toshiba DC-SB1 remote control model, and I think the problem might be that you're pressing the wrong button. Try pressing the "skip track" button right below where it says close caption on the remote. It's deceiving because, based on where the words 'closed caption' are, it looks as if the stop button is associated with it, but it's not. That's what I was doing wrong, it may be a different problem for you though.
Posted on Dec 15, 2008
Epeltie1 is right! Just hit the dislay button and then the 'skip track' button until it goes to nothing. Should work.
Posted on May 13, 2009
I can get closed caption on many stations, but not on Hallmark and I can on a cheap TV. What can I do to get it on Hallmanr?
Good question. Set your channel on the hallmark channel. Then go to your menu to the control that turns captioning on. Turn it off, then turn it on to see if it works. If this doesn't work try to reset the entire unit. Unplug the unit, wait 2 minutes. Turn it on , go through the procedure to find channels, turn the caption control to on and see what happens. If that doesn't work I'd ask your tv service provider of contact customer service at the number listed in your users manual. Good luck. Closed captioning is required by law under the Federal Americans with Disabilities Act. Its gotta be there some where or they can't get a license to operate a station.
Mar 26, 2015 | Emerson LD195EMX 19-inch LCD HDTV/ DVD...
Sharp Aquos LCD TV 52"
Does your cable company support CC?
Apr 08, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I just bought a new remote and cannot find the user guide for the TV. Do you need to program the remote for it to work?
Hello
You have to programme it. do the following:
[1] Make sure there are working batteries in the Toshiba remote control.
[2] Turn on your television set, DVD player or other device that you want to control with the Toshiba remote
[3] Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
[4] Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
[5] Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
OK.
Jul 19, 2011 | Toshiba DC-SB1 Remote Control
How do I remove the closed caption or dialoge text at the bottom of the screen
U have the tv original remote wright?Yes,look at the tv remote control,look for a button that said CC,push that CC button a few times make sure all CC1,2,3..all to off closed captioning should stop.No CC button on the remote.Go into the tv main nenu look for functions like Text 1,2,3.. and closed captioning 1,2,3... turn it all to off will fix the problems also.
Jul 08, 2011 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Can not get closed captions on dvd to play on sony tv with captions on tv set on.
Hi, you might have to turn the CC feature off from your TV and select the CC feature from the DVD disc set up.Refer to page 35 of the owners manual to get the correct language caption on your disc(dvd): basically press the audio key on your remote control until the desired captioning appears.
Jun 21, 2010 | Toshiba SDV395 DVD Player/VCR
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
Closed captions
Closed Caption may only come on when you have the television muted.
Mar 10, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Toshiba MD19N1 19 in. TV/DVD Combo Logo
810 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
