Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Sony KP-53HS30 Visual Problem
Ok heres the deal, yesterday I went to move the cables in the back of my TV. After making sure all of the connections were in place, I experienced my TV having visual problems.
The display seems to curve inward towards the center of the screen. Also, there is some ghosting where colors are off. I can still watch TV but it looks like I need 3D glasses now.
This is really unbelievable that a problem can occur just by checking wires. I hope I do not need to replace any part.
Is there anyone that knows how to get this fixed and if so can you please give step by step instructions because I know many people have the same problem! I checked many many sites for the last 2 days and I can't find someone with a complete solution. All I ever see is "go to the service menu"! What settings do we use after!? Anyways hopefully someone can help me and others instead of just a generic response.
TIA
  • Gladiator2k Dec 11, 2007
    Thanks for the link, but I don't think this is the route I want to go, is there any way I can fix the set through the service menu?
    Does anyone have any experience when the set is like this?
    Thanks either way ctf1800
    President:
  • 4,402 Answers
Sounds like a loose connection on the convergance amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Dec 11, 2007
  • Cary Farah
    Cary Farah Dec 11, 2007
    if the set is left like this you will burn up some resisters and ic's and then the set will turn off. best to call for service or a friend that knows how to solder.
Our Sony KP-53HS30 53" HD-Ready Rear Projection TV
According to the tech manual I looked at, it's a bad board - it just doesn't say which board. Sorry. Looks like it's making a trip to the shop.
Good luck.
Jul 06, 2011 | Sony KP-53HS30 53" Rear Projection...
My picture is red
if you are using component cables, make sure all are plugged in on both the back of the tv and the cable box. (component cables will have a red and white audio and red, blue, green video)
Oct 19, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Pink image on Sony KP-53HS30 TV
Pink? If this is a retangular box that appears then I would suggest to look into the fact that you have turned on "TEXT" mode within the "CC" closed caption settings.
Jul 23, 2009 | Sony KP-53HS30 53" Rear Projection...
Connecting the laptop VGA output to my Sony-KP-53HS30
There are products such as VideoSecu PC to TV Presentation Converter. I haven't used them. I'm not sure you are going to get the resolution that you want. A DLP projector does a pretty good job. I know that is not what you are looking for.
Type "PC to TV Converter" in Google. They are about $40 to $60 bucks. Before you buy one, read the reviews.
Dec 27, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony projection tv kp-53hs30 made nov.2003
do you think you can take a picture and send it to this website
Aug 08, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30
Yesterday I got the same with RED color.
I guess ptoblem is with Hi voltage multyply HVB-1031//x.
Not sure yet... still looking for info
May 02, 2008 | Sony KP-53HS30 53" Rear Projection...
I have the same problem as faye95. My Kp-53HS30 tv clicks on and then turns back off and red light blinks on and off. Can anyone tell me what the problem is and where can I get a free service manual o
Free service manuals are hard to find and often they are complete. You can get the sony factory service manul at the following link for 15.99 and they will give free unlimited online tech support when you get the manual. They email the manual and info on getting the support instantly after purchase. heres a link if you would like.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony CONVERGENCE
are you experienced technician ? if you are not you are gone to mess up your tv you need to replace 2 IC's stk392-040 check power supply if still ok and get in to service mode to make the convergence aligment and is not that easy contac andrews electronics in CA they have squematic for
Mar 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Progressive scan
progressive scan? does your tv support 720p, or 1080p HD? (the p actually stands for progressive scan).
Another alternative to that is: http://www.playerschoicevideogames.com/pd_psp.cfm
A bit more expensive, but i think it works on any tv.
Jan 06, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
