Nikon FG 35mm SLR Camera
Problem for Nikon FG 35mm SLR Camera
Film Won't advance
By cooge468 on Sep 13, 2009
I haven't used my Nikon FG in a few years, when I tried to use it again I could not advance the film. When I press the trigger doesn't open, so it isn't already wound, but it will not advance as if it were already wound. I can't load film in it because I can't advance the film. Any ideas?
Best Solution
posted on Sep 15, 2009
Very Helpful)
Obertelli
Rank: Guru  Nikon Cameras & Camcorders  Expert
Rating: 94%, 301 votes
When cameras are unused for a while the lubricants dry out and cause things to stick. In regular use the lubricants keep getting redistributed internally so thin films of lube do not get a chance to gum up. Another problem is that almost all cameras over around ten years old will have decaying foam light seals and mirror bumpers which not only gum the works up but the sticky goo is corrosive if left in place.
Ideally your camera needs a CLA service (clean, lubricate, adjust) and providing you haven't broken or bent anything by brute force the camera should be fine afterwards. All cameras (and lenses) need a CLA every so often to maintain peak performance and reliability, regardless. For a one off additional fee a CLA will also include a foam removal and replacement service in which the old foam is carefully removed and where necessary replaced with inert modern materials which last far longer.
If you don't want to invest in a service then you can sometimes get things ungummed by leaving the camera somewhere warm overnight (around 40 degrees C, 104F). If the lube hasn't dried out too much and if the foam hasn't thoroughly gummed things up then this can just soften any seized up parts enough to allow them to free off under gentle pressure and repeated operation. Note that if this works then it's not a replacement for a CLA but will at least confirm that there's nothing seriously wrong. You'll still need to invest in a CLA and foam replacement if you intend to continue using the camera.
In the UK you can typically expect to pay anywhere from £60 - £100 for a CLA and foam replacement and as demand far exceeds supply you can expect a six week turnaround time. In North America I find that repairs are typically a bit cheaper but the turnaround times are similar and in the Far East I can get these repairs done both cheaper and far quicker (especially in Kuala Lumpur, Malaysia).
Once the CLA is done you can expect many years of flawless operation if you're an amateur photographer and if you're a pro you'll get a CLA done annually as it's essential maintenance and in most countries it's offset against business tax.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Nikon FG 35mm SLR Camera
Questions and Unsolved Problems for Nikon FG 35mm SLR Camera
Do you recommend Nikon FG 35mm SLR Camera?
Answer
Answer
mirror is not straight
Answer
what type of battery do i need for a 35mm nikkon slr film camera?
Answer
Before I put new batteries into my Nikon FG, I tried clicking the shutter button. The curtains on... (More)
Answer
New battery didn't work. Tried M90/no luck.
Answer
Can you tell me how to load film in my camera?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nikon FG 35mm SLR Camera:
Top Film Camera Experts
Rank: Guru Guru
Solutions: 756
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Film Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
