Question about Sharp AL-1642CS Copier
Problem with H4
I want to do first the solution 1 but I don't know how to reset the code by entering the simulations and using code 14 to reset?
  • ESP597 Dec 11, 2007
    Thank you very much. It solved the problem. what a genius you are! It's now working as good as new now! Good work fellow!
Thank you very much for the explanation, 'cos in the way that you explain this solution is very easy the solution for this problem.
and it works!!!
thanks again trickieone
Posted on Jun 23, 2008
    Novelist:
  • 208 Answers
Here is the process.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time
Posted on Dec 11, 2007
  • Rick Kasper Dec 14, 2007
    Your welcome.
    Glad to be able to help.
I what to know how to input simulation program to clear maintanance code CA on Mx2610 sharp copier
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 10, 2016 | Sharp Office Equipment & Supplies
HOW CAN i CLEAR h4?
OR
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY.
Dec 04, 2015 | Sharp AR-M160 Laser Printer
How do i remove or cancel error message h4 on sharp digital ar-153e copier
OR
Oct 23, 2015 | Sharp Office Equipment & Supplies
How do clear H4 error code on Sharp Copier arm256
OR
Aug 02, 2015 | Sharp Office Equipment & Supplies
H-400 error on Sharp 165
OR
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
May 29, 2015 | Sharp Office Equipment & Supplies
Have Sharp - AR-5516 and H5 error blinking on the screen
OR
Mar 28, 2015 | Sharp Office Equipment & Supplies
Error h4 on sharp at m318 copier
OR
Mar 16, 2015 | Sharp Office Equipment & Supplies
How do i fix a h4-01 error code on my sharp ar m277 copier
OR
Feb 26, 2015 | Sharp Office Equipment & Supplies
How to reset the Maintenance indicator sign in SHARP AR 5618
OR
When the
Dec 09, 2012 | Sharp AR-5320 Black and White Copier
I am getting a flashin L and can't make copies?
L1 = Scanner (reading) feed trouble Scanner (reading)
L3 = Scanner (reading) return trouble Scanner (reading)
Reset method :
* Entering the simulation mode
1) Clear key ON - Exposure mode select key ON - Clear key ON - Exposure mode select key ON
(The machine is ready for entry of the main code of simulation.)
2) Main code input by 10-key ? Start key ON
3) Sub code input by 10-key ? Start key ON
The machine enters the selected simulation mode.
Press the start key to start the operation of the selected simulation.
Main Code =(14 Used to cancel the self diag other than U2 trouble.)
Sub code = 0
* Canceling the simulation and returning to the normal mode
1) Press the clear key.
Copy SIM 14
Sep 07, 2010 | Sharp AL 800 Copier
42 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
