This is only happening with duplexed prints; standard prints are coming out flawless. I have replaced the duplexer unit, which has not fixed the issue. I am only using genuine Konica Minolta High-Yield toner -- it's dirt cheap nowadays -- and have also replaced the drum unit -- again genuine. I have cleaned the various rollers that are accessible from inside the top cover. I did recently adjust the Registration Roller Solenoid, but did not replace the worn felt pad. Could this be causing the issue?
SOURCE: KONICA MINOLTA magicolor 2490MF paper jam. It
I believe the duplex door is in the back of the printer.
SOURCE: Bixhub c351- I can copy in duplex but i can not print in duplex
Have you told the print driver that you have a duplex fitted, also is the paper set as plain as any thick setting will cancel out the duplex function.
SOURCE: My Savin 2560 (same as
www.copyrite.org.uk/Ricoh%20Copiers/Ricoh%201060.pdf
Above is a user manual, perhaps this will help, below is
http://support.ricoh.com/bb_v1oi/pub_e/oi_view/0001036/0001036377/view/ps3/unv/0105.htm
Do you have the Duplex Unit installed, and also the firmware too i imagine... I would wonder if it's installed? Usually with these types of things, it just works, and is easy to find and do..
If using the Apple system then look below...
http://discussions.apple.com/thread.jspa?threadID=2590567&tstart=0
