Question about Proview XL370B (Black) 17 in. Flat Panel LCD Monitor
Mag Innovision PS976KQ
Sometimes plays up. It can work perfectly for weeks and then for few day it gets this washed up hue over the screen. Then it works all right again.
0 characters
1 Points
MAG Innovison LT685 an Mac OS 10.9.2
Considering your file is a media file you should go for digital media recovery software. I can suggest you few, must try Stellar Phoenix (, Disk Drill ( and Wondershare (
Mar 02, 2014 | Mag Innovision LT Computer Monitors
MAG LT765s monitor, model 780; where do i plug in adapter
Sometimes the power adapters on flat screens face the floor. So, if you look under the screen under the stand, you will likely see the plug.
May 22, 2010 | Mag Innovision InnoVision LT765 17" Flat...
I have a MAG INNOVISION LT765s LCD monitor. When the computer boots up, the power button on the monitor won't stay on so the display won't come on. It sometimes takes an hour of fooling around with the...
I have had similar problems with my Mag LCD monitor. I recently dicovered that the problem was with the adapter and not the monitor. Try replacing the power adapter.
Sep 21, 2009 | Mag Innovision InnoVision LT765 17" Flat...
Mag Innovision LT917s 19 inch monitor- On and Off !!
Replace it.  It would probably cost more to get it repaired.
May 28, 2009 | Mag Innovision LT917S 19 inch Monitor
I have a 2002 MAG INNOVISION FLAT SCREEN MODEL 780. I use this monitor as a dual monitor with my lap top. However today I still can view everything but with a pink hue. I have gone to the color controls on...
This could be a problem with the monitor's data cable. Try to check it & find if there is any bent pins on the connector.
If this is not the case, there could be a loose connection on the monitor's PCB, or a failing component. This needs to be checked by a qualified technician.
Apr 12, 2009 | Mag Innovision Computer Monitors
The monitor with no picture
There are few possible reason that the screen doesn't comes properly. You should check these things carefully 1. Make sure the capacitor chipset is good . 2. Soldering need to be perfect ( because if you put more than it needed then sometimes it make problems). 3. Check the LCD paper displaced or not.
May 27, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Color problem MAG Innovision 14" monitor
1. try to connect to another computer . if it is fairly good then it must be your computer is having a problem.may be your video card problem.
Mar 21, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Mag Innovision 765S Screen Flashes on and off.
It sounds like it is trying to re-synchronize it self and not going back the the default setting. Compare the resolution of the game to your monitor capabilities.
Dec 29, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
Proview XL370B (Black) 17 in. Flat Panel LCD Monitor Logo
61 people viewed this question
Top Proview Computer Monitors Experts
 Mike M
Mike M
Diego Zenizo
Diego Zenizo
Level 1 Expert
Are you a Proview Computer Monitor Expert? Answer questions, earn points and help others
