Question about Frigidaire Affinity ATF7000E Front Load Washer
Firgidaire washer
The e20 code keeps coming up, only 6 months old what does this mean?
  • 6 more comments
  • auntkalei2 Feb 09, 2008
    E 20 keeps coming up and the washer won't drain. Now it isn't spinning either. I took the hose off the back thinking that maybe the hose was stopped up, but it isn't, and even with the end of the hose going into a tub, the washer won't spin or drain.
  • Anonymous Mar 28, 2008
  • Renee Stanfill-Marasco Mar 31, 2008
    Washer is about 6 months old, won't spin, has water in it. check out drain hose, it is clear.
  • Junior10 May 08, 2008
    E20 error code every time I wash. I cleaned out the hose (was not clogged) and still get the same error. What now?
  • mojomike Jul 01, 2008
    My Washer is less that a year old and I have been less than thrilled with it's spin cycle. Now however, I can't get the wash to run through a complete cycle without an E20 code. Please help me. It is driving me mad!
  • Justin5309 Sep 28, 2008
    I looked under the washer and found the opening to the interior. I disonnected the gray hose from a white plastic piece. The connection had a rubber flap that separated the two. I looked inside the white plastic base after lifting the flap and saw nothing. Is this the correct hose that the filter should be contained within??
  • threej83 Apr 10, 2009
    have washer out. ours sets on drawer can you get to these hoses in the back or bottom?
  • Anonymous Apr 10, 2009
    E20 code keeps coming on...my washer is 1 1/2 yrs old.
  • 3 Answers
I think I figured this one out. I think it means that the washer is not able to drain, therefore it won't spin either. Underneath the washer is a series of outlet hoses and within one of them is a filter. When I finally found the filter it was clogged up with lint, fibers from a pillow and coins. You have to dig the filter out and then clean the filter and rehook up the hoses, this was relatively simple even for me. The washer works perfectly now.
Posted on Apr 07, 2008
My washer was giving me the e20 code and when I had a repair man come out all he did was adjust the hose in the back of washer by sticking the end down in the drain and MAKE SURE the excess hose sticks up higher than the washing machine.
This causes a suction that will drain water out of washer. You might have to get creative like hold it up with broom handle something. Its the HOSE! I
Posted on Apr 21, 2009
In regards to hanseren above....how did they not have anyone to repair your washer? They have contracts with service people. What was the problem with the washer?
Posted on Jan 25, 2010
    Problem Solver:
  • 7 Answers
Frigidare replaced my washer with a brand new one, they did not have anyone to do the repair, I even got a newer model, the 6000 is no longer made.
Tumble action washer keeps giveing me E20
first, find a manual or contact tech support to determine what an e20 means. it could be a clogged drain.
Jun 02, 2014 | frigidaire.com
What does werror code e20 mean
check your filter if that is clear check your pump
Feb 09, 2014 | Frigidaire Washing Machines
E20 keeps coming up on my washing machine
E20 Error Code - means, not draining
It seems more as an issue of a clogged drain line, filter go to bad or malfunction pump.
Hope this helps.
Mar 31, 2011 | Washing Machines
My 6-month old topload WF 8702CPG keeps stopping in the middle of the cycle with the code LE. Going crazy tyring to figure out what's wrong. Error code not in the manual. What does it mean and how do I...
this means the lid safetey switch is a bit out of adjustment LE means Lid Error. if you press down on th lid it might take the error away while you are pressing. without breaking the lid. This will prove the lid error. A warranty call may be necessary . 6 months old must be under warranty Good Luck
Sep 11, 2010 | Washing Machines
Each time I make a copy, half of the sheet come normal whilst the other half is soiled black. Then comes the error code E20-0034A OR E20-0460.
E020 is verry wide meaning error code, only that I can help you,without seeing the machine, is service manual.Write on emma.servis@gmail.com
Aug 08, 2010 | Canon CLC 1000 Color Copier
I have a 97 Buick Regal and I get a E20 error message:cd player
If the CD is over 60 minutes it will not play on domestic cars
May 29, 2009 | 1997 Buick.5 Regal
What does E20 code means on a delco cd player?
Hi E20 mean's
The CD player cannot focus on the disc or there is an internal focus problem.
try a known good CD and if it still displays E20 then you will have take it to a radio repair shop
May 10, 2009 | 1997 Pontiac Sunfire
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
5,615 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
