Question about Onkyo TX-SR604 Receiver
Hum from speakers
I get a significant hum from the speakers when the receiver puts out a signal to the speakers. I have the receiver wired by HDMI cable from a satellite receiver to the Onkyo to an HD TV. The microphone autobalancing trys to eliminate the hum by setting the speaks in - db which doesn't work.
    Problem Solver:
  • 6 Answers
I suspect an open ground or bad cnnection in your hdmi cable to the amp from the sat.A hum is very indicative of that situation
Posted on Jan 09, 2008
Whats wrong with my stereo
How old is your HK receiver? The power supply capacitors can get old and tired, and cause the hum and shutoff. Repair is an option.
May 03, 2015 | Harmon Kardon Harman Kardon AVR1600 50W/CH...
Major hummimng noise when sub is connected to receiver.
Is the hum in the receiver-attached speakers or the sub?
Self-powered sub?
How is the sub attached - RCA or speaker-level?
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
If it hums with the sub attached, unplug the sub's power cord. Differences in AC ground potentials will generate hum across linked devices.
Mar 25, 2011 | Yamaha RX-Z9 Receiver
BACKGROUND HUM PRESENT AT ALL TIMES
What sources do you have connected to the receiver? The thing to do is to disconnect your sources one at a time and see if one of those eliminates that hum.
Jan 03, 2011 | Audio Players & Recorders
My home theater speakers make a constant hum whenever my receiver is on. The loudness of the hum changes with the volume control, and goes away entirely when the system is muted. All components are plugged...
jd40,
Sounds like a grounding issue. The first two places to look into is the powered subwoofer and antenna. During your last test, did you leave the FM antenna and subwoofer connected? Many times the hum is directly related to the antenna and/or the subwoofer and to how they are grounded; creating a ground loop through the receivers ground on the outlet. If the antenna is grounded to the dwellings wiring, hum is inevitable and sometime you can get a ground loop hum from how or how & where the subwoofer is grounded. Try taking them completely out of the loop.
Also try taking it further back to the basics, start with the receiver plugged into a known good grounded outlet with no surge or line conditioner in the loop and nothing connected to the receiver, nothing. Use one speaker and different wire to test each speaker output while in tuner and any other mode but phono. With no signal, you will either get nothing (no hum or static) or just static in the tuner mode. No hum is a good sign. Some systems will mute the speakers if no signal is connected to eliminate the static from being produced through the speakers but a ground loop hum will most likely still be produced even in mute. If you get a hum when nothing is connected to the receiver, try looking into getting a better grounded outlet, even maybe to a different dwelling.
-Chris
Jan 30, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Humming speakers
If you disconnect the signal leads and the hum is away, it's probably a groundloop problem, or your equipment is generating the hum.
If it does not go away, the amps are defective
Sep 23, 2009 | Mackie SRM-450 System
Is there an incompatibility between Onkyo 606 and KEF Wireless?
This is cycle hum place offending units away from each other or, isolate the power supplies and, re- check electrical circuit grounds
Jun 01, 2009 | Onkyo TX-SR606 Receiver
Pioneer Receiver SX-750: Getting a loud hum through the speakers
The hum you hear from the speakers and from the unit itself originate with 60hz AC power. They may not actually be related. Sometimes a transformer will hum slightly and unnoticeably. That you're getting a loud speaker hum says there is an electrical leak or a grounding issue somewhere.
Do all sources produce the hum or, say, just the phono? How about on headphones? Try rotating the AC plug. In those days they weren't keyed with one large blade as they are now.
May 17, 2009 | Pioneer Audio Players & Recorders
Wire antena (that came with SS5 system) causes a hum
It is assumed that the hum is coming down the aerial wire it self....The hum should be eliminated
dissappear if you remove the wire from its connector at the rear of the receiver.
If this is the case then reconnect the aerial and try to find a radio station to listen to..
When you find a station you will find the hum dissappears as follows:
When there is no station detected the receiver tweaks up its sensitivity via the Automatic Gain Control, (AGC) and when this happens any thing that is detected on the aerial is reproduced at the speakers and in your case its just a hum.
I have heard this event lots of times and mostly its scrackles or scratchs or other weird sounds which come down the aerial while the AGC is flat out at maximum..
The radio station transmits a sound "carrier" and within this carrier there is the music content.
The receiver detects the "carrier" when you tune to the radio station, and then it sets its receive
level to the setting made by the volume control and then lovely music is presented at the speakers..
So in fact your receiver is working as it should be ,.,,, no worries mate....
Now if the hum is still there when the music is there then you have a fault, but as you havent mentiond this aspect your receiver is in my view quite "normal".
Cheers For Now
From YUBEUT..
Sep 19, 2008 | Nakamichi SoundSpace 5 Shelf System
Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Aug 04, 2008 | Bose Acoustimass 15 System
Humming from speakers when CD player running
Yes, The humming is always there you just can hear it better when the cd is playing. The humming is caused by the electrical system in your car. There is an inline filter you can buy and insert it between the car's power source and the head unit. I had a head unit I bought that was absolutly terrible until I installed that filter. Also if you did a do it yourself job on your amp wiring it is usually best practice to run your RCA cables on the opposite side of the car as your power cable. You can also purchase shielded spark plug wires which is a source of noise usually of a different kind tho. First make sure you have a good ground. This means that you have grounded your amp to bare metal not painted metal. If that didn't work put in the inline filter on the head deck as they are only $20 available at radioshack. If that doesn't work, go back an wire your car right this time and put the power and RCA on opposite sides of the car. If you still have that hum it may be the spark plug wires but that sounds more like static than hum. You have a text book case of alternator hum... Hack
Jul 11, 2007 | Xtreme Sound WMS336 CD Player
Onkyo TX-SR604 Receiver Logo
337 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
