Question about Toshiba 32AF43 32" TV
36 inch toshiba Tube tv manifactured in 1997
I had a cable box hooked to the tv and now just want to go direct to the cable without a box. I can't get it to pickup the signal through the coax connection. Is their a way to switch from s video to coax/
  • Anonymous Mar 25, 2014
    How do I connect my Toshiba 27AF45 32" tv to direct tv box
  • 1,694 Answers
Program TV =
1) set-up.....Select CATV also called STD Cable
2) Auto-program channels.........
.......Owners manual ? Let me know.................T.
Posted on Dec 11, 2007
if you are using a cable box, tried to reset. then tried to unplug any connectors that has been hooked to the component input of your tv.
Oct 26, 2012 | Toshiba 50 Inch Big Screen Flat Tv Theater...
How to hook up cable box to model tz55x71 manufactured 2000 diagram please
You can Google the model number of the Toshiba for a 'manual" or owner manual which will show your set.
Usually with a cable box in goes to box and out to cable fitting on rear of set and set to channel 3. Output of a box with audio/video cables is same except they connect not to the cable fitting but to the rear inputs on back of set.
FYI most cable companies will come out, connect it and hook it up for little or no charge.
May 20, 2012 | Toshiba 50 Inch Big Screen Flat Tv Theater...
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Feb 10, 2012 | Toshiba 42H82 42" Rear Projection...
Is this model HD ready?
Yes,this tv is able to play HD signal,but must have pay cable or satellite signal hook it up to it.This tv is CRT-(tube tv) analog design tv,antena alone will not work without a converter box.
Feb 17, 2011 | Toshiba 50A50 50" Rear Projection...
I have a toshiba 36 inch television, magnabox dvd player and cable box hooked up. I can't get the television to channel 4 and I don't have the manual to get the remote for it to work. We use the remote for...
Oh yes clear on what your saying, Channel 4 needs to have signal to it during the scan!! So i hope this VCR or whatever you hooking up to it is set for channel 4 and its on and playing so a signal is marched threw it when your autoscanning. Without a remote this is a priceless fail i would recommend get the remote for your TV and you should be able to navagate the menu fine. You also can put all you stuff on inputs to advoid the tuner all togeather.
Thanks we understadn what your saying and would like to help you in this manner but without a remote that works its will be hard to explain over email but please scan the channels when the thing is playing so it can detect a clear signal.
please do help us out by pressing the accept button for our efforts today!
Jan 12, 2010 | Toshiba 36A40 36" TV
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
I have a 36 inch toshiba tv do i need a coverter Box
If you have cable or satelite/direct TV etc, no converter is needed. If you use an external antenna to receive over-air broadcasts, please post the model number and I'll let you know. The changeover in February only effects over-air broadcasting.
Sep 12, 2008 | Televison & Video
Toshiba 36AFX61
Just Connect signal to tv and run autoprogram. Or use video input jacks from converter to tv ( yellow,white and red video in ) and select tv/video on tv pannel front ( don't need remote control) I hope this work for you.
May 11, 2008 | Toshiba 36AFX61 36" TV
Toshiba TV CZ36T31 & Toshiba SD1600U
go to here you will get user manual you will get all information along with figure. good luck.
Oct 07, 2007 | Toshiba CZ36T31 36" TV
Toshiba CF36G40 36" TV (picture snowy)
you have a bad tuner you can replace it or use vcr if you still have one around. hook it up with av cable like your ps2 and hook your cable to it and use it to change channels. If you want to replace the tuner it will require soldering and you will have to order it somewhere. i would try The tuner is the metal can the cable goes into inside the tv.
May 12, 2007 | Toshiba CF36G40 36" TV
Toshiba 32AF43 32" TV Logo
242 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
