I have a Pavilion DV6220LA that won't start. I pressed the power button and all the lights are on but no futher movement. No error message, nothing on the screen, and after a while it reboots itself but stalls right after turning on with all the lights on. I left it rebooting for days but saame thing happened over and over again.
I check the thread posted by leetyger (my model is not included in the list) and reviewed the HP link posted by h0lmes, the solution posted by Bigman2009 and did a hard reset, tried the solution # 6 by morcindo44 and I still have the same problem.
I started a chat session with HP support and after about one hour they told me I have a BIOS problem and should take the unit to the nearest service center.
I hope someone can help me here. Thanks in advance.
Lets try this before we give up all hope.
when you start having this problem it's normally caused by a critical
systems error. worry not.. with a little time on your part we can fix
this- this is how-
Go here
using a torrent program ie (utorrent,
shareaza, etc) download SPINRITE.exe. Burn this on a disk, the program
is written with freedos included, but this will not work with 100% of laptops.
if freedos won't allow the program to run successfully then you need to
use a program such as PowerISO to burn the disk and make it a bootable
image,
after burning the program to disk-
this may take a few hours or a few days depending on the condition of the HDD.
I
have used this program to fix computers I've picked up on the side of
the road. I would power it on, start to load then go into a loop. after
running this program overnight I was able to reboot (after removing
disk) and the pc started right up.
Make sure you run a program
like Ccleaner (you can get at www.fileippo.com) to clean your registry
and junk files after completion. ^_^
Thank you for the advice.
This won't do it for me, I press the power button but the unit does not do anything but turning on the leds on the unit. No BIOS activity, no CD drive detection, no HDD activity, nothing, just the LED lighted up.
Thanks anyway.
