Question about Haier HWR10XCA Air Conditioner
Haier a/c no manual
Lost manual/ set temp on a/c- walk away lcd temp gauge starts adjusting on its own/ please help elderly woman/energy saver/3 speeds' also has light that comes on/ f or h
  • Anonymous Jun 05, 2008
    I do not have a manuel and they aren't available on line for this model.
  • 259 Answers
Here is the maual you need. Hope this helps. :]
http://www.haier.com/admin/en/product/upload/HWR10XCA-USER%20MANUAL.pdf
Posted on Dec 11, 2007
Run a service test for kitchenaid dishwasher
Did you check behind the toe-kick panel for the tech data sheet? Assuming that you have checked and that it is missing, there here is the "secret keystrokes" that will make most Whirlpool/ KitchenAid/Kenmore/Maytag diswashers enter the diagnostic cycle:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 18, 2014 | KitchenAid KUDS30IXSS Builtin Dishwasher
How to disable energy saving on KitchenAid Range
The Energy Saver Mode deactivates the display to reduce energy
consumption.
To Activate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver on."
will appear in the upper text area.
2. The setting will be activated after 5 minutes.
Any cooking function may be used with the range in Energy
Saver Mode by simply selecting the desired function.
To Deactivate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver off."
2. The clock will reappear in the display, and the range can be
operated as usua
Oct 10, 2012 | KitchenAid Ovens
Reset kenmore dishwasher
The most common "reset" key sequences are:
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry).
Jun 15, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Is there a reset button on the dishwasher? if so, where?
Not sure what type of reset you are after. Is the dishwasher not responding to any panel switches.
Is the keypad locked, i.e., is the control lock light on? Then press Energy Saver Dry button for 4-5 secs.
Are some lights flashing and dishwasher will not start? Have you tried to turn mains power off and back on?
If you think the controller needs a reset, you could try this sequence of keys within 7-8 secs.
hi temp scrub/ energy saver dry/hi tempscrub/ energy saver dry/ hi temp scrub/ energy saver dry.
If the reset sequence has worked correctly, then all lights should light up. Press Cancel to exit from reset mode. I am assuming you have a users manual. If not then download from here.
Please rate the solution if it helps your problem otherwise post a comment
Feb 18, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
I want to adjust/disable the energy saver on a Panafax 9000
Press Function 74 set scroll down to ENERGY SAVER make it INVALID set stop
May 12, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Moved into new house need set of instructions
Try this. I'm not sure if it applies to your model.
The reset sequence used is:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
Jan 19, 2009 | Kenwood KW85 Air Conditioner
Window air conditioner HWR08XC7
Could be a lot of things, make sure the temp sensor is clean and is in a position to sense the air temp flowing over it. Other than that it could be out of calibration.
Jun 09, 2008 | Haier Heating & Cooling
Haier hwr10xc6 thru-wall/window air conditioner
Does the unit have an energy saver or timer feature? It should be on the top front panel of your unit. If so, read and follow the directions in your manual. If you still have problems, contact Haier at their toll free Customer Service helpline.
Apr 25, 2008 | Haier hwr10xc6 Air Conditioner
Lost manual for wine fidge
Push the red and white buttons at the same time for about 3 seconds-the temp will start to flash-then press the white button to lower the set temp-when you have it where you want it then push the set buttom
Oct 18, 2007 | Haier HVF060A Wine Cooler
Haier HWR10XCA Air Conditioner Logo
170 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Bonded Repair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
