Question about Panasonic DMR-E50 DVD Recorder
Recording and erasing stopped working after 3 yrs.
My DMRE50 has stopped recording and all functions like erasing after 3 yrs faultless service. Still plays fine. When trying to record it comes up with a variety of messages that result in a crash and then it tries to recover. Sometimes, I have to power off the machine and use "OPEN" to turn it back on to get the disk out
Is there some way of cleaning the record heads ?
  • Anonymous Feb 14, 2008
    1.DVD-RAM (Panasonic or TDK) usually records but sometimes fails to start.
    2.Recorded disk plays ok.
    3.Erasedisk usually works but sometimes sets recorde into a "Recover" mode.
    4."Recover" goes into a loop and recorded stops responding to commands.
    5.Re-formatting disk (in recorder) sometimes helps but not always.
    6.Cleaning laser does not improve.
    7.Turning off/re-setting/ all usual basic things have not cured fault.
    8. Can I get a DMR E-50 software re-install?
  • Anonymous Mar 07, 2008
    exactly same problem. 3 year old unit which cost 300 pounds new :(
    help!!!
    Problem Solver:
  • 5 Answers
Try Recording and eraseing on a DVD-RAM a lot until you can get it to erase a DVD-R that it has recorded but not finalized.
Then try recording on a non-finalized DVD-R that has previous recordings but still has some room left to record. Erase a program and record another show on the same dvd.
Try this untill it will finalize a track on a non-finalized disk and repeat, make a few tracks. Then record on that disk untill it's full and finalize the disk.
Once you can get it to record on and finalize a few disks that it had previously recorded on it should be able to accept new fresh un-recorded DVD-Rs.
Posted on Apr 12, 2008
Yup I have the same problem with ERASE and non recording. I have tried a lense cleaner, which I thought did work initially, however now it's not having it at all.
I have taken the thing apart to have a poke around but still no joy - apart from the discovery of a few 'spare' parts!?!? lol
Still I think the problem is with the RAM disks as I have a really old disk which which I have hardly used and this will still erase and record on demand. Hope this helps...
I ended up here becase but my remote has stopped working now with the message "Remote DVD 1" appears on screen when you try to use it, but nothing happens!?!?
Posted on Mar 11, 2008
    Genius:
  • 1,003 Answers
TRY USING A DVD LASER LENS CLEANER
Posted on Jan 23, 2008
How do I delete a recording off my Sony Sony - ICDBX140 - 4GB
  1. Slide the HOLD?POWER ON/OFF switch in the direction of "POWER ON/OFF" to turn on the IC recorder, or towards the center to release the IC recorder from the HOLD status. The stop mode window appears.
  2. Select the file you want to erase when the IC recorder is in the stop or playback mode.
  3. Erase a selected file. When the IC recorder is in the stop mode, press and hold ERASE.
    When the IC recorder is in the playback mode, press ERASE.
  4. Press ERASE. "ACCESS" appears in the display window and the selected file will be erased.
    When a file is erased, the remaining files will advance so that there will be no space between files.
Hint
  • To cancel erasing, press souni_stop.png(stop) in step 3.
  • To erase a part of a file, divide the file into two files first, and then proceed with steps 3 through 4.
Mar 10, 2015 | Sony Video Cameras
Hi i own a RCA digital voice recorder model# rp5030A i can not figure out how to delete recordings
Erasing selected file
You can delete a file by the following steps:
1. Select folder (A, B, C , D or )
2. Select file.
3. Press ERASE once and DELETE will blink on the screen.
4. Press and hold ERASE for 3 seconds to confirm deleting. (or press STOP to cancel erasing file)
Erasing all files in a folder
You can delete all files in a specific folder by the following steps:
1. Turn on the unit.
2. Select a folder (A, B, C , D or ).
3. In Stop mode, press FORWARD continuously until "ALL" appears on the display.
4. Press ERASE and "DELETE" will blink on the display.
5. Press and hold ERASE for about 3 seconds, all files in the selected folder will be erased completely (or press STOP to cancel erasing all files).
Tip: File numbers that come after erased one will be moved forward by one automatically.
See page 12 for more info: http://www.rcaaudiovideo.com/docs/common/RP5030/RP5030_OM.pdf
Dec 29, 2012 | RCA RP5030 Digital Voice Recorder
The recorder dosent errs why
Hello you can erase the recorded messages one by one or all massages in folder at time
Note once a recording has been erased, you cannot retrieve it.
Erasing messages one by one
1 Press ERASE while playing back the massage you want to erase or press ERASE for more than 1 second during stop mode.
A beep will sound and the message number and "ERASE" will flash while the first and last 5 seconds of message is played back 10 times
2 Press ERASE while the message is being played back.
The message is erase and the remaining messages will be renumbered. (For example, if you erase Message 3. When erasing is completed, the unit will stop at beginning of the following message.)
Erasing all messages in a folder
1 Press FOLDER to select the folder you want to erase.
2 While pressing STOP, press ERASE for more than 1 second.
"ALL ERASE" will flash for 10 seconds
While the display is flashing, press ERASE.
Nov 16, 2010 | Sony ICD-B7 Digital Voice Recorder
Lost manual can't ERASE RP 5010 recorder by RCA
folder
2. Select a folder (A/B/C/D).
continuously until “ALL” appears on
the display.
4. Press ERASE and “DELETE” will
Apr 07, 2010 | RCA RP5010 Digital Voice Recorder
Philips 720 transcription machine won't erase tapes - no previous problems encountered carrying out this function with the machine.
Hello Press the PLAY and REWIND keys at the same time the LCD display shows the fast rewind symbol together with an S to indicate that the tape is being erased backward. The erase function continues until either the beginning of tape is reached or another function is selected. if this does not work Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Jan 18, 2010 | Philips Desktop 720-T Desktop Cassette...
Need manual for panasonic E50
http://service.us.panasonic.com/OPERMANPDF/DMRE50.PDF
Dec 24, 2009 | Panasonic DMR-E50 DVD Recorder
I need to delete a recording
2. Select file.
3. Press ERASE once and DELETE will flash on the screen.
2. Select a folder (A, B).
3. In Stop mode, press FORWARD continuously until “ALL” appears on the display.
4. Press ERASE and “DELETE” will flash on the display.
Aug 14, 2009 | RCA RP5010 Digital Voice Recorder
Unable to delete files from the recorder
Resetting the Recorder (CLEAR)
This function resets the current time and other settings to their initial
status. It is useful if you are having problems with the recorder, or if you
want to erase the entire memory of the recorder.
1 Hold the STOP button, and hold the ERASE button for 3
seconds or longer.
2 Press the FF or REW button to select the “YES”.
3 Press the PLAY button.
Jan 14, 2009 | Olympus VN-2100PC Digital Voice Recorder
PANASONIC DMR-E50
Apr 08, 2008 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-E50 DVD Recorder Logo
179 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
