Question about Refrigerators
Whirlpool Side-by-Side Refrigerator GD5SHG
The house we bought a couple of months ago came with a whirlppol Side-by-side Refrigerator model GD5SHG (partial number). It stopped cooling on both sides a couple of days ago.
The coils were completely blocked with dust on the front and I have cleaned that. The condensor fan is running. The condensor is running I think - it sounds as if it is cycling on and off rather quickly.
Looking on the internet I see that the defrost timer tends to go out causing the evaporator coils to freeze and suggest checking the evaporator coils, as well as adjusting the defrost timer until the fridge shuts off.
The problem I have is that the back of the fridge is a sealed panel (apart from the lower section behind the compressor, fan, water connection) and I don't see a way to get it off in order to check the coils. I don't think they were iced up; however, as I have had the fridge off for the better part of the past 36 hours and there is no water in the pan at the bottom of the fridge.
According to the parts manual I found on the Whirlpool website, the defrost timer is at the top of the fresh foods section inside the control panel and I don't see how to access it.
There has been 3-4" behind the fridege since we moved in.
What am I missing? Is there anything else I can check prior to calling a repair guy?
  • 1 more comment
  • Thawed Dec 12, 2007
    Thanks! Trying a few more things last night, I did pull off the start relay and it does need to be replaced. I will try that tonight and hopefully that will take care of it.
  • Lawton nonex May 06, 2008
    I own a whirlpool GD5SHA*k*0 side by side. This morning I came downstairs to find water on my floor and my freezer defrosted. Vents on interior are clear, and I pulled off the front and back to make sure they were clear of "dust/gunk" buildup (they weren't but are now). I hear it "clicking" like it's trying to turn on, but it doesn't seem to be getting any colder. Compressor felt very warm.
  • gbohannon Jun 28, 2008
    I got up this morning and my freezer was defrosted. I thought one of the kids left the door open, so I went ahead and cranked it up one notch, nothing. Everything else seems to be working, but I can hear the compressor kick in, and then it immidietly kicks back off. Freezer and refig aren't very cold, but lights are working. No ice is being made either? Help
  • 410 Answers
Access to the evaporator area is from inside the freezer compartment behind the shelves. but from what your describing, "The condensor is running I think - it sounds as if it is cycling on and off rather quickly." it sounds as though the compressor is not starting up and running. you may try replacing the start relay that plugs on to the side of the compressor..
Posted on Dec 12, 2007
The water and ice started tasting very bad with a sulfur chemical taste a few months after the water filter was replaced. What should I do?
Did you recently have a water main break in your area about the time the bad taste started or any plumbing repairs in the house?? Could be the filter is contaminated. Try another filter and go from there. If problem is gone it was the filter. If still there---possible problem with refrigerator water system and tubing.
Mar 15, 2015 | Whirlpool ED5LHAXW Side by Side...
Ice maker leaks water-whirlpool GD5SHG
please check fill valve as it could be open. also check if supply tube at the back in the freezer is plugged with ice. check if the fan running in the freezer
May 13, 2014 | Whirlpool Gold White-on-White 21.9 cu. ft....
My whirlpool ice maker heater sayed on an flooded the kitchen,could timner stuck.
Sounds like your ice maker is defective, Here is a Whirlpool ce Maker Manual
2198597 Ice Maker Assembly
The PDF above may be helpful because it shows what to look for
in diagnostics on the Whirpool Ice Makers. I will be here to answer any questions you have, Sea Breeze
Feb 12, 2013 | Whirlpool GS6SHEXMB / GS6SHEXMQ /...
I have replaced the computer abbout 4 months ago and now the rerigerator keeping shutting off and now everyday i have to s=re set it
Could you please send me your model number of your Whirlpool Refrigerator so That I may investigate the problems the refrigerator is causing you. I will need that to begin finding why you are needing to reset on a daily basis. Thanks, Sea Breeze
Nov 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Bad Odor in Whirlpool Conquest Refrigerator
put boxes of baking soda opened in the frig. The baking soda will absorb th odor.
Sep 21, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Grinding, Howling Sound Coming from Freezer
You almost certainly have a defrost fault building up ice around the fan
Mar 15, 2017 | Whirlpool ED5FTGX Side by Side...
Fridge frozen
hi thanks for the question yes would replace the thermostat thanks the appliance doc
Aug 08, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side compressor replacement?
uk price is about £250 fitted i done one about 2 months ago. or thats what my company charge
Feb 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidaire Refrigerator - Model # FRS26ZSG
The housing is probably cracked due to it freezing.
Dec 02, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
989 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
