Question about Dryers
Whirlpool dryer my dryer is only blowing cold air after replacing heater core and thermastat
    Sergeant:
    Champion:
  • 262 Answers
CHECK AND SEE IF YOU HAVE 220 VOLTS AT THE WAAL AND THE DRYER CHECK LEFT TO CENTER AND SHOULD GET 110 VOLTS SAME WITH RIGHT AND CENTER LEFT AND RIGHT WIRES SHOULD BE 220 VOLT IF YOU DONT HAVE THIS THE DRYER WILL RUN BUT NO HEAT SO YOU MIGHT HAVE DROPPED A LEG OF POWER
Posted on Dec 13, 2007
Car heater is blowing cold air
Explain how you had a mechanic work on the problem
& not resolve
If the hose from the water pump is hot & the return from
the heater core is not ,then there is a control valve somewhere
Some mechanic that is
We don't have a data base to look up that ,we are at home like
you,social web site
Nov 21, 2012 | 1999 Chrysler Cirrus
Fans are blowin cold air but wont blow hot air
needs to replace the heater core
Apr 25, 2012 | Cars & Trucks
Heater blowing cold air replaced thermastat next day heater blowed hot then it started blowing cold again has a new radiator and the water is not low
Flush coolant system out first with prestone or peak coolant flush if problem still exist replace heater core.
Apr 05, 2011 | 2001 Chevrolet Blazer
Replaced blower motor and resistor, also heater core and thermastat, and control panel in dash, still only cold air blows out.
most likely your problem is the temp blend door actuator it is a motor that moves a door in heater case to adjust temp
Dec 24, 2010 | 1997 Chevrolet Cavalier
Im not getting any heat blows cold air. i changed the thermastat and nothing. it was blowing out hot air in the vent setting but nothing now.
need to check your blend air door located behind the dash on the passanger side, if that checks out good then you have a blockage either in your heater core or hoses to/from the heater core.
Jan 17, 2010 | 1999 Ford Taurus
I have a 1998 Dodge Dakota 5.2/ V8 4X4 and was told the Firestone service Rep that my water pump and thermastat were defective. I could smell coolant both outside and inside the truck. Also when the heater...
If the heater core isn't leaking it doesn't likely need changing. It sounds like you could have a problem with the heater control valve - a valve in one of the heater hoses that controls flow through the hose. If you smell coolant and see moisture on your windshield (inside) or have coolant leaking onto the floor - you might need the heater core replaced.
Jan 15, 2010 | 1998 Dodge Dakota
Blowing cold air--- engine light on
it could be the thermostat or the heater core id try the thermostat 1st and go from there
Jan 25, 2009 | 2002 Jaguar X-Type
Air conditioning blows nothing but cold air. can't get heat.
IF U ARE TRYIN TO GET THE HEAT U CAN DO 3 THINGS
1. TURN HEATER ON THE FACE/FEET POSITION AND PLACE ON HIGH, TAKE THE RADIATOR CAP OFF AND CONTINUE TO POUR WATER/COOLANT UNTIL HEAT GETS HOT
2. CHECK/REPLACE THERMASTAT
3. CHECK/REPLACE HEATER CORE
Jan 20, 2009 | 1996 Ford Taurus
Heater blows cold air when idle
Sounds like you may have a partially plugged heater core. You could flush this out separately, from flushing radiator & engine block. Diconnect heater hoses going to your heater core and clamp off, so not to loose coolant from engine. Now hook up separate hose to one side of heater core pipe and flush out with typical garden hose. Repeat procedure on both heater core inlets. Reconnect original heater hoses and test difference. You may have to add an additional litre of antifreeze. If this don't work i suggest changing heater core. Good luck.........Ron.
Jan 03, 2009 | 2000 Jeep Grand Cherokee
Open Questions:
Dryers Logo
59 people viewed this question
Top Dryers Experts
Marvin
Marvin
